Can I use TPMS and lugs from "steelies" on Gulf States Rims
Discussion in 'Wheels & Tires' started by jfjacques, Mar 11, 2011.
  1. Mar 11, 2011 at 5:35 AM
    jfjacques
    jfjacques [OP] Active Member
    JamesJ
    Maine
    2010 Tacoma DBL Cab V6 6spd
    Agri-Fab LiteRider Tonneau Weathertech vent visors
    Hi -
    Looking into some gulf states rims and wondering if I can re-use the lugs and/or TPMS from my steelies on 2010 DC 4x4?
    Assuming I should have no problems using the stock tires for now until budget allows a replacement of those.
    Thanks for any input.
  2. Mar 11, 2011 at 5:40 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    The steel rims have a different angled sensor.
    You can use a strap kit, build a pipe bomb, have the tire guys turn the sensors. Either way, you will have to break down your stock steel rims to get to the sensors then to do it to the other set if there is tires already mounted.
    The ids off your steel sensors are programmed into the tpms ecu there is only room for 5 numbers.
    If you buy just new rims, the strap kits work great, many members use them here and cost is aroun $50 plus whatever labor. A good tire shop should help you out.
    As far as the lugs I have heard different info.
    I know when I swap my tires/rims for winter, the lugs look different from oem steel rims to oem alloy. So I have a set for each.
    The guys can explain it better.
  3. Mar 11, 2011 at 2:46 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The gulf states alloys take conical seat (acorn style) lugs.
