Can i use trd sport front strut and rear shock on my trd offroad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ukeacreator, Apr 20, 2022.
  1. Apr 20, 2022 at 3:34 PM
    ukeacreator
    ukeacreator [OP] Well-Known Member
    Nikolas
    BC CANADA
    2016 Grey Tacoma TRD OffRoad
    285/75R16 DURATRACS FUEL VECTOR 16 3 INCH CUSTOM LIFT
    So basically my truck needs two shocks for inspection. Mine leaked out. I plan on doing full suspension upgrade eventually. My friend just took oem ones off his sport and i can have for free he said. I was going to paint them yellow and be done with it till i can afford Fox all around. Will they fit in trd off road coil and on the rear?
    Friend has a 2020 trd sport
    I have a 2016 trd off road
  2. Apr 20, 2022 at 3:54 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Yeah they should fit just fine. Not sure if the coils will fit though.
    Can you just pressure wash all the oil off your current shocks so they look fine? or do they actually test them?
  3. Apr 20, 2022 at 5:29 PM
    ukeacreator
    Nikolas
    BC CANADA
    They never removed them and tested them, he gave me a small list and said pop back in when thats done so we can confirm quickly and he will give me a pass. I would be using the coils on my TRD off road but it will be trd sport front strut and rear shock. Im assuming its pretty to easy to tell if they have been replaced when its up on a hoist and theres no weight on them so i doubt hosing them will work
  4. Apr 20, 2022 at 5:35 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I've never heard any report of the stock coil springs being different on any of the trims. The TRD Pro are painted red, but I'm not sure they have any other differences; not that it matters in your case. You can check if the part numbers are different on parts.toyota.com
    Are you sure your shocks are bad? Does the truck oscillate up and down after hitting a bump?
    Replacing shocks is a little tricky. You need a spring compressor or you can use one of the jack-based methods documented on youtube.
    ukeacreator[OP] likes this.
  5. Apr 20, 2022 at 5:47 PM
    ukeacreator
    Nikolas
    BC CANADA
    Ya im not looking forward to it but ive changed struts before, was more just wondering if they are the same cause the sport is more for on road so i thought id check
  6. Apr 20, 2022 at 5:48 PM
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    Yes, the sport shocks will work fine.
    If your friend has the entire coilover, that will make you life easier (shocks with the springs installed), but either will work fine as a replacement.
    They are not the same, but they will work.
    na8rboy likes this.
  7. Apr 20, 2022 at 5:54 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Put all of them on. Should fit fine. Don't mix and match.
    na8rboy likes this.
  8. Jan 15, 2023 at 10:01 AM
    Keywerk
    Keywerk Member
    Sean
    Phoenix
    14 4x4 DC LB Sport
    I am curious if you followed through with this and what you thought.
    I am considering putting Sport Hitachis on the front and OR Bilisteins on the rear. My thought is for the front to have the planted feel that I am used to with the 2nd Gen Sport, and the rear to not bounce so harshly over bumps.
  9. Jan 15, 2023 at 10:04 AM
    Hercanstein
    Hercanstein Well-Known Member
    Bryan
    State of Jefferson
    1999 2.7 SR5 4x4 5MT XC, 2020 3.5 TRD Sport 4x4 6MT AC
    ('99) Offset Aluminium Wheels, 31" BFG All-Terrains, Bushwacker Fender Flares, Window and Hood Wind Deflectors ('20) Stock
    This.
    ancient11 likes this.
  10. Jan 15, 2023 at 10:04 AM
    Hercanstein
    Bryan
    State of Jefferson
    I LIKE that idea!
