CAN I?
Discussion in 'Audio & Video' started by chaos316, Oct 11, 2011.
  1. Oct 11, 2011 at 11:02 PM
    chaos316
    chaos316 [OP] Well-Known Member
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    285/75/16 BFG KO2 Ditch Lights
    JUST WONDERING IF I CAN MOUNT 3 10" W3S IN THIS BOX, AND IT SOUND GOOD? THE MOUNTING DEPTH FOR THE W3s SAYS IT REQUIRES 5.93 INCHES, AND THIS BOX HAS AN OPTIONAL 6". OR WOULD I BE BETTER OFF GOING WITH 3 10" W1s
    http://www.supercrewsound.com/05tacomadbltriple.html
  2. Oct 11, 2011 at 11:18 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    or even 2 10" w3s in the dual box they sell
  3. Oct 12, 2011 at 12:34 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
  4. Oct 12, 2011 at 12:54 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    Look on the back of the woofer. If it has a relatively square shouldered vent for the magnet pole piece, you should have a minimum of 1/2" behind the woofer (and no stuffing in that area). The new JL W3s seem to be side vented, so you could probably get within 1/8" if the box is well made (no flex).
  5. Oct 12, 2011 at 12:55 PM
    pyroskier
    pyroskier Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
    I DON'T KNOW MUCH ABOUT AUDIO, CAN'T REALLY HELP SORRY
  6. Oct 12, 2011 at 1:03 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Not sure if it will fit, but if you are having to yell when you talk you probably have damaged your ears enough already and shouldn't continue with stereo upgrades.
  7. Oct 12, 2011 at 4:54 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    LoL! Nice.
    W3's are nice, but they have pretty good travel. I'd be wary of them wearing on the back of the seats. The specs say it will fit, then try em.... just be warned.
  8. Oct 12, 2011 at 11:19 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    haha i didnt realize my caps lock was on. but i just want to bump again. my last setup was in a single cab s10. i was running a jl audio a2150 amp with a one 10w1. i personally thought it hit pretty hard, but then again it was my first system with a tiny amp. i still have the amp and sub. what do you guys think i should do? build a new box for the 10w1 and keep the old setup? or get 1 more 10w1 and a bigger amp? i now have a 2nd gen dc
  9. Oct 12, 2011 at 11:25 PM
    chaos316
    JJ
    Wichita, KS
    2017 Cement TRD PRO
    thanks man. would the box from super crew sounds work?
  10. Oct 12, 2011 at 11:42 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    http://www.youtube.com/watch?v=7Dt5Nf7ct5c
