Can LT lifts be done in stages?
Discussion in 'Long Travel Suspension' started by Greenhatter, Oct 21, 2011.
  1. Nov 2, 2011 at 3:11 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Would you rather be, or a log?
  2. Nov 2, 2011 at 3:59 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    say what??? lol
  3. Nov 2, 2011 at 4:16 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Haha its not supposed to make sense. Was making fun of your post (I realize you missed a word)
  4. Nov 2, 2011 at 4:21 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    oooooooooooooooooooooooooooooooooooooh. haha
  5. Nov 2, 2011 at 4:30 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
  6. Nov 2, 2011 at 4:31 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I fixed that one earlier :cool:
  7. Nov 3, 2011 at 2:28 PM
    Greenhatter
    Greenhatter [OP] Well-Known Member
    Washington
    Silver 2008 TRD Sport
    TRD Supercharger, Toyo Open Country M/T 285/75/16, 16" TRD Ivan Stewart Wheels, Clearbra
    Thanks for all the excellent info and advice guys. If I have serious intentions of going LT down the line, is there a lift treatment that is a good transitional lift? ie. Many of the parts will be used for the LT as well? For example, having a 6" DB lift would allow me to do the LT lift in halves (front and rear) right? Or if I went mid travel would I be able to use the same COs, UCAs, etc.? Its hard for me to swallow spending $3k on a 6" DB lift or a proper 3" suspension lift if I will have to replace the entire lift again when I pull the trigger on LT. As always thanks for the patience with a rook.
  8. Nov 3, 2011 at 2:32 PM
    Cr250jumper
    The moon
    50 shades of tan©
    No, there are no parts shared in a 6" DB lift and LT. Spend as little as you can on stuff that will get thrown away when you do LT. I did my front end and only added an add-a-leaf (1.5") to the rear until I LT the rear. Im not wasting any money on parts to make it look "cool" during the build
  9. Nov 3, 2011 at 2:35 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    There's not really anything that will help you transition because LT completely replaces everything. A drop down bracket lift will be a huge step in the wrong direction, as they require cutting the stock crossmember off and that will have to be welded back on when you go LT.
    If I were you, I'd put 2.5'' Remote Reservoir OEM replacement coil overs up front (Fox, King, etc.) and run Camburg or TC UCA's (to correct your alignment). Get the TSB in the rear and run Bilstein 5100's. The front end will out run the rear but it will be a large improvement over stock. This will help you decide if LT is for you.
    When you are ready to go LT, do the rear end first. With CO's and UCA's up front and LT in the rear, you will be able to haul some ass. Save up some more, go LT up front, and you will be flying.
  10. Nov 10, 2011 at 11:53 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    ^QFT!
