Can my Taco tow this trailer?
Discussion in 'Towing' started by mrkabc, Nov 11, 2019.
  1. Nov 11, 2019 at 9:46 PM
    mrkabc
    mrkabc [OP] Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    2017 TRD OR V6 with Tow Package.
    Trailer:
    2020 Springdale 189
    • Hitch Weight: 455 lbs
    • Dry Weight: 4228 lbs
    • Length: 23' 7"
    • Cargo Weight: 1727 lbs
    I plan on getting an Equalizer WDH, and a Tekonsha 90160 brake controller. I'm in CA so I don't expect large hills/mountains. I get the ECT/S4 restrictions, and here in CA we have a 55 mph speed restriction for trailers anyways.
    I'm new to the travel trailer scene so thoughts/opinions are most certainly needed!
  2. Nov 11, 2019 at 9:51 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Is the cargo weight of 1727 total allowable weight of tanks and cargo ? Or just cargo and then add wet tanks?
  3. Nov 11, 2019 at 9:53 PM
    mrkabc
    Art
    Corona, CA
  4. Nov 11, 2019 at 9:55 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Yes, though it might not be fun. You’re looking at close 5000lbs once loaded with a normal amount of stuff and a whole lot of wind resistance. You won’t be going fast or very far between gas stations.
  5. Nov 11, 2019 at 10:05 PM
    Bishop84
    Bishop84 Well-Known Member
    I'd rent a similar trailer first and see how it does.
    I wouldn't buy a trailer that I could possibly regret.
    tacoRenner and Jasonstacoma like this.
  6. Nov 11, 2019 at 10:06 PM
    mrkabc
    Art
    Corona, CA
    Thanks guys, I think this one will be a hard pass. I will look for something smaller. :thumbsup:
  7. Nov 11, 2019 at 10:07 PM
    stealthmode
    Alberta
    I think your on the right track with WDH and brake controller. Steady pace and good driving you'll be OK. Just OK though IMO. If your through consistent grades frequently you might get a bit uncomfortable with being able to maintain decent speed and keep up safely with traffic.
    I was quite comfortable with no WDH or brake controller with 4000 lbs. Manual transmission for me though. Screenshot_20191111-230220_Gallery.jpg
  8. Nov 11, 2019 at 10:20 PM
    DJFRENZY
    DJFRENZY Well-Known Member
    Bay Area, CA
    I tow an Airstream Sport 22FB at a dry weight of 3,634 lbs and hitch at 422 lbs. I've towed this from the Bay Area across Nevada, Salt Lake Utah, Yellowstone National Park, Arco Idaho and back. I've also towed on highway 1. I added a leaf and it definitely helped. I plan on adding a leaf pack once the current ones gives up. I also have an equalizer WD and brake controller. The only challenges I've faced were high winds. Not the best tow vehicle but it works. 11—13 MPG.
    Thunder Fist likes this.
  9. Nov 30, 2019 at 10:09 PM
    mrkabc
    Art
    Corona, CA
    Thanks guys! I ended up with a Jayco Jay Flight SLK7 195RBW.
    Thunder Fist and slamson00 like this.
  10. Mar 2, 2020 at 11:27 AM
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    Any update on the Taco tows it? We are looking at a similar sized RV. I haven't even attempted it but when I had my Chevy 2500HD Diesel I had a 23footer at 4500lbs Dry. I think it will be too much for the Taco.
  11. Mar 4, 2020 at 11:16 PM
    mrkabc
    Art
    Corona, CA
    Taco tows the 195 RBW just fine. This trailer is lighter than the one I originally wanted, and a bit smaller. Fully loaded is 3750 lbs. Dry weight is 2900 or so. I'm using a WDH and Tekonsha P3 brake controller. Taking her out next weekend to the desert, will post pix! :)
    https://www.jayco.com/products/travel-trailers/2020-jay-flight-slx-7/195rb/
    Is the link to my trailer. Good luck!
  12. Mar 7, 2020 at 2:49 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    ive hauled more on ' flat to level ' terrain when i had my V6 4door long bed.............. No issues
    U have to keep an eye on ALL temps
    Radiator / Tran etc
    no less ambiant temps are significant
    most haul campers occasionally reasonable distances
    not likely U will be in top gear or overdrive
  13. Mar 18, 2020 at 8:40 AM
    RVguy
    RVguy Member
    2015 Tacoma
    If you haven't already purchased the WDH, give the BLUE OX SWAY PRO serious consideration. The sway control is built into the hitch design,,,no need for a separate friction sway bar (I don't recommend this).
  14. Apr 26, 2020 at 11:41 PM
    mrkabc
    Art
    Corona, CA
    Jayco pulls just fine! Got in a little desert boondocking before COVID got serious.
    @RVguy I have an E2 WDH and a Tekonsha P3 brake controller. So far so good!
    Boston10Taco, TacoManOne and 1776Taco like this.
  15. Apr 27, 2020 at 12:02 AM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Add a leaf and dont underestimate sumo springs. They do wonders for towing and bed weight. Helps alot
  16. May 27, 2020 at 7:37 PM
    ROAD DOG
    FEW
    if U arent goin for a lift
    firestone air bags work Great !!
    work with most any situation if Ur Taco aint lifted
    full bed
    passengers
    etc
    simply air up / level out the bags
    does NOT make the ride harsh !!!!
    when done level out to normal
    Silentshredr likes this.
  17. May 29, 2020 at 1:10 AM
    mrkabc
    Art
    Corona, CA
    More boondocking over Memorial Day weekend.
    Twize likes this.
  18. Jun 6, 2020 at 10:59 AM
    SWNewMexico14
    SWNewMexico14 Well-Known Member
    Justin
    Silver City, New Mexico
    2011 Tacoma TRD Off-road
    3in lift, Bilstein 5100 Ome coils front. Bilstein 5100 Ome el095r leaf springs. Hooke Road roof rack. Lil BS fab cab mount relocation. eBay snorkel.
    Awesome man! I have a similar trailer we took it out Thursday just got back was a quick trip. Weighs just around the same dry as yours.
    mrkabc[QUOTED][OP] likes this.
  19. Aug 1, 2020 at 10:23 PM
    mrkabc
    Art
    Corona, CA
    You have the Baja though, those come with 15" wheels and flipped axles. Nice rig! What's your water tank capacity?
  20. Aug 6, 2020 at 7:11 AM
    SWNewMexico14
    Justin
    Sorry for the late response it’s a 30 gallon fresh.
