Can offset effect rubbing?
Discussion in 'Suspension' started by Datsik, May 25, 2012.
  1. May 25, 2012 at 1:53 AM
    Datsik
    Datsik [OP] Well-Known Member
    San Diego
    2012 4x4 Sport
    Stock
    I'm currently running Eagle 50s 17x8 with 20mm offset 5.19bs with 285/70/17s and I'm not getting any rubbing what so ever... Although, with the 2005 tacoma I sold it had 17x9 0 offset and it rubbed a little. Kind of curious if the 2012s changed the wheel well space for more clearance. Anyways... I'm looking to buy the KMC XD775 Rockstars that are 17x9 with a -12 offset. I plan on transferring the tires to the new wheels but I'm curious if I will encounter rubbing issues with the new offset.
    The reason why I'm changing the set up is to get wheels that stick out a bit more than the ones I'm running.
    Biggest issue - in relation to suspension - is if offset does cause rubbing, then I'll chop the cab mount.
  2. May 25, 2012 at 5:19 AM
    Large
    Large Red
    To answer your question - yes. But there are a lot more factors to contribute to rubbing.
  3. May 25, 2012 at 8:02 AM
    DevL
    DevL Well-Known Member
    You will have to chop the cab mount.
  4. May 25, 2012 at 8:12 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I'd like to see how close the tire is to the UCA with the 17 x 8 20mm rim.
  5. May 25, 2012 at 9:55 AM
    Datsik
    San Diego
    2012 4x4 Sport
    Stock
    It's pretty close. I'll have to take a picture when I get back from Yosemite.
  6. May 26, 2012 at 1:37 AM
    Datsik
    San Diego
    2012 4x4 Sport
    Stock
    lol... A little embarrassing, but in my defense I have new wheels and tires that arrive this wednesday that will fit much better. I've only ran this setup for 67 miles exactly and it's staying in the garage until the other wheels arrive. Although, no rubbing or indications of wear from the UCAs.
  7. May 26, 2012 at 4:48 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  8. May 27, 2012 at 8:24 AM
    Datsik
    San Diego
    2012 4x4 Sport
    Stock
  9. May 27, 2012 at 8:34 AM
    TacoLife08
    TacoLife08 Well-Known Member
    GA
    08 DC PreRunner TRD Rugged Trail SR5
    Camburg 4' Spindles, top plate spacers, 2" AAL, 285/75R/16 Terra Grapplers, Tinted Windows, Black Riveted Grille, Black Spyder Halo Healights/Tailights, FlowMaster 40 Exhaust, NFab Side Steps, Blacked out Skid Plate.
    Since when do xd rockstars come in a 17
  10. May 27, 2012 at 11:22 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    that is too close for comfort for me. your new wheels will provide you better clearance on the uca, but you will most likely have to do a little wheel liner cutting. if you wheel any, you should consider doing the cab mount chop mod.
  11. May 27, 2012 at 11:41 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    less backspacing will help you clear the UCA but may cause rubbing on cab mounts etc. 4.5" backspacing is generally best for these trucks - not too little, not too much.
  12. May 28, 2012 at 10:04 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  13. May 28, 2012 at 10:32 AM
    Datsik
    San Diego
    2012 4x4 Sport
    Stock
    I do wheel but Ive decide to keep it close to stock with advise from KPT and his build. 18x9 265/65/18 with 0 offset. Bilsteins set to 1.75. And yes they do come in 17s since...always I think? Check out the XD website
