can our composite truck beds hold a car motor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Feb 10, 2010.
  1. Feb 10, 2010 at 1:18 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    i searched. i am planning on bringing a 911 race motor back from portland. not sure about weight, guessing 400-500 lbs? will all the hardbits crack my bed? i have seen some threads about the beds cracking? i figure the composite material is pretty strong, but a concentrated loaded bouncing up/down?
    i'll lay down some plywood, and strap the thing in for sure.
  2. Feb 10, 2010 at 1:34 PM
    Yota1
    Yota1 Well-Known Member
    rest the motor on on old tire, and then strap it in. the tire will cradle it, and act as a shock absorber.
    done this several times, never in a taco though, but it should handle the weight fine
  3. Feb 10, 2010 at 1:36 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    ^ that is a good idea with the tire. Just make sure you strap it down correctly and it wont damage anything
  4. Feb 10, 2010 at 1:44 PM
    matt86
    matt86 Well-Known Member
    NC
    2008 Tacoma SR5 4x4
    I transported one in my old 2007 Access cab. We set it on a tire and had it leaning back on the tailgate and strapped the shit out of it. It was scary at first but the Taco handled it well.
  5. Feb 10, 2010 at 1:51 PM
    rods55
    rods55 Active Member
    abingdon, maryland
    06 dc,4x4, LB, trd sport
    K&N drop in, tonneau cover, C2C hood struts, black out grill emblem, fog light mod, sec. air filter removal mod,2" front level kit, debadged
    i've had a big block chevy(454) and a turbo 400 auto trans in the back of mine with no problems, it made it sag in the ass alittle
  6. Feb 10, 2010 at 1:56 PM
    aficianado
    back to bone stock.
    old tire is genius! thanks.
  7. Feb 10, 2010 at 2:14 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    08 4cly
    Dule Magnaflow Exhaust dumped behind axle, K&N Air intake, Aftermarket radio with a kicker L5 sub & a shit amp, 18" rims with tires, RHLM, DT header, color matched bumper, oem foglights, 8k hids in headlights and in fogs
    well if your worried about the weight it will be more than fine i have had a ton of crusher fine in the bed and i drive an 08 reg cab 2wd.
    but if your worried about scratching just put a piece of ply wood in the bed and yes the old tire is a great idea.
    but deff make sure you tie it down correctly! if you need to hit the breaks hard and its not tied down right that would be a situation haha.
    anyway hope it all works out!
  8. Feb 10, 2010 at 2:22 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Why do people keep asking if a truck with a 1200+ lb payload can handle 500lbs in the bed?
    As said before, steel really isn't that strong in the great scheme of things, it's just cheap for the amount of strength you get out of it.
  9. Feb 10, 2010 at 2:23 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Sold the ol girl
    highly doubt it would crack the bed. doesnt the composite sit on the metal bed?
  10. Feb 10, 2010 at 2:24 PM
    jandrews
    There is no metal. The bed is made of composite material.
    Which, for the record, is quite a bit stronger than steel by weight.
  11. Feb 10, 2010 at 2:26 PM
    JAG
    JAG Well-Known Member
    He was just wondering if that jagged structure of the engine in a specific spot in his bed would crack it... Heck somehow... I don't know how... but the front of my bed is cracked... I hate that composite crap. It just fiberglass mesh.
    I think it was a legit question esp since he searched... IMO
  12. Feb 10, 2010 at 2:27 PM
    aficianado
    back to bone stock.
    500 lbs, concentrated at a point load..stress=P/A.
    steel is ductile..it bends.
  13. Feb 10, 2010 at 2:32 PM
    Cars0n`
    Carson
    Edmonton AB
    Sold the ol girl
    seroiusly? i thought it was a composite bed liner..
    if not how does the tacoma at the dealer with no bed liner get explained? they sell a truck without the composite bed?
  14. Feb 10, 2010 at 2:32 PM
    Taco505
    Alex
    New Mexico
    08 4cly
    well anything has a breaking point even the stongist of things, IMO its better to just ask instead of finding out the hard way i have deff done that more than once, but thats just my 2 cents....
  15. Feb 10, 2010 at 2:34 PM
    Taco505
    Alex
    New Mexico
    08 4cly
    the bed liner is the composite bed, get under your truck and take a look there isnt any metal or at least that i have seen...
  16. Feb 10, 2010 at 2:37 PM
    Cars0n`
    Carson
    Edmonton AB
    Sold the ol girl
    weird i thought i seen metal when i was washing it.. maybe i just figured it was.. anyways back on topic sorry for the thread jack
  17. Feb 10, 2010 at 2:41 PM
    jandrews
    Valid point about concentrated load on a point. Hadn't thought of that.
    Steel does indeed bend...but it also corrodes and is heavier. I prefer the composite bed.
    Not an 05+ they don't.
    Yeah, aficianado made the point. Essentially, in a steel bed, the same situation would result in a mondo dent, which I can see being less problematic than a crack.
    The SMC is a fiberglass reinforced compound. Exactly which compound Toyota has yet to specify (and probably won't). But yes, the lack of ductility is the only significant downside. Although a bed mat pretty much solves that issue, one could validly argue you shouldn't have to buy an accessory to make your vehicle impact resistant.
  18. Feb 10, 2010 at 2:50 PM
    Cars0n`
    Carson
    Edmonton AB
    Sold the ol girl
    the one i seen was a brand new 2010 base model 4x4 i believe but it had no composite bed.. just steel. :)
  19. Feb 10, 2010 at 2:52 PM
    wingshootin
    wingshootin Well-Known Member
    Jonathan
    Columbia, SC
    2006 Taco LB TRD Sport 4x4
    3" suspension lift Custom wheels Oversized M/T tires
    I transport my 4 wheeler in the bed of my Tacoma whenever i take it anywhere and have never had a problem with.
  20. Feb 10, 2010 at 2:53 PM
    wingshootin
    Jonathan
    Columbia, SC
    Other than when I decided to drive it through my back window.....but that is a different story.
