Can remote resi adjusters compensate for no sway bar?
Discussion in 'Suspension' started by cementnotgray, Feb 2, 2021.
  1. Feb 3, 2021 at 1:18 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    My Fox 2.5s look pretty awful half way into their 2nd Midwest winter and I’m a fluid film user.....my frame and underbits have faired much better. No issues otherwise though, FWIW
    Tough area to keep clean, and the film doesn’t last long in those areas....wool wax would prolly be better but I think it’s the nature of the beast
  2. Feb 3, 2021 at 2:02 PM
    cementnotgray
    cementnotgray [OP] Well-Known Member
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    Have you had Kings before for comparison?
  3. Feb 3, 2021 at 2:14 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I have not, no. No idea if one is worse off than the other, sorry
  4. Feb 3, 2021 at 3:45 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    I'm just saying, I can't finds any pictures of Kings rusting the same way I've seen Fox rusting
  5. Feb 3, 2021 at 5:52 PM
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    You said not a "tremendous" amount; it sounds like it would help in some way then. I know it won't remove the need for a sway bar but will it make a noticeable difference?
  6. Feb 4, 2021 at 8:05 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Both shock brands will rust bc they have steel bodies. In the near future (hopefully) Fox is moving to an aluminum body coilover which will keep them from rusting. Fox also has better piston rods which will last through more abuse than Kings... like we discuss in that article I posted a link to. Stiffening up compression will do something, but it's controlled more with rebound, not something you can adjust manually on these shocks.
    01 dhrracer likes this.
  7. Feb 11, 2021 at 8:54 AM
    btot588
    btot588 Well-Known Member
    South Louisiana
    2015 Tacoma TSS 4x4, 2001 4runner
    Softopper, led bed and hood lights, rigid ditch lights, blue sea fuse block, wet okoles, weather tech floor mats and window shades, and more...
    Elka for better resistance to rust.
  8. Feb 11, 2021 at 1:04 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    I'm planning to coat my Fox rears (when they finally get here from Accutune:boink:) with plastidip to deter theft. I wonder if that will help prevent rust.
  9. Feb 11, 2021 at 1:12 PM
    Ncpi007
    Ncpi007 Well-Known Member
    Charlotte, NC
    2018 Tacoma TRD Off-Road
    I literally did this on Monday-Tuesday. Installed 2.5 Radflo's with adjustable resi and 700 pd spring. Removed the sway bar, set the stiffness to maximum and I cannot tell the difference driving without the sway bar.
  10. Feb 12, 2021 at 5:33 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Sway bars only really come into play during extreme maneuvers, like swerving for something on the road at highway speeds. Doubt you'd ever notice it in normal driving, regardless of shocks
  11. Feb 12, 2021 at 6:35 AM
    Ncpi007
    Charlotte, NC
    Totally disagree, if I set them on soft and drive straight down the highway at speed, I feel a little sway or rock, it is slight, but there. When I exit the highway, again on soft, the lean is incredible. Adjusters to hard, no sway..... Just my experience this week with the new Radflo's and sway bar delete.
