Can shift 5spd when not running, but NOT AT ALL when running.
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaveCanuck, Apr 28, 2023.
  1. Apr 28, 2023 at 11:36 AM
    DaveCanuck
    DaveCanuck [OP] Well-Known Member
    Dave
    Canada
    2011 SR5 V6
    1996 Tacoma 4x4, 3.4 5spd.
    Just had a bunch of work done (shocks, water pump, timing belt, tune up) and driving it home from the mechanic, shifting got progressively more difficult, and now I can't shift at all.
    Would this be a clutch cylinder issue?
  2. Apr 28, 2023 at 11:41 AM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Possibly. Just run it back and have it checked. Anything thing short of that is a guess, and a waste of time.
  3. Apr 28, 2023 at 11:43 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    The first thing to do is check you clutch fluid.
    rocknbil and cruxofthebisquit like this.
  4. Apr 28, 2023 at 11:44 AM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Definitely something within the clutch system, not necessarily the hydraulic side. Look at the reservoir and see if the fluid level is low/gone.
  5. Apr 28, 2023 at 11:50 AM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    Fluid level is ok, but it's dark.
    Now this might be completely unrelated but prior to today I did find when shifting from 1st to 2nd there was a noticable thud. Not a clunk, but a thud. That wasn't present today.
  6. Apr 28, 2023 at 12:01 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I always change both master and slave cylinder and it works like new for a lonng time. Seems like whenever I piece meal it, it acts up again shortly. Even if it turns out you need deeper work (probably don't if not slipping) you'll always want a new M/S cylinder anyway to go with new disc.
    Ozark_RegCab likes this.
  7. Apr 28, 2023 at 12:17 PM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    Is something like this an expensive job?
  8. Apr 28, 2023 at 12:18 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Agree on the fluid, I had (stupidly) let my clutch fluid get low and apparently got air in it, got hard to shift. I suggest completely flushing/bleeding the clutch system until it's clear, mine was black too. Consensus is it leaked out somewhere, but everything is dry as a bone.
    This may not fix it but it's the least costly thing to start with.
  9. Apr 28, 2023 at 12:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You have to look at the throw of the slave cylinder against the clutch fork. If it's not moving far enough you have a hydraulic issue - outside the trans, master cylinder, slave cylinder, etc. Look for fluid leaking out of the master cyl and dripping down the firewall inside by the pedal. If the slave cylinder isn't leaking it's fine.
    If it's moving a good enough distance and still have trouble shifting then you have to pull the transmission and inspect the clutch unit for damage - broken/worn out pressure plate springs, bent release fork, etc
    That's the fork in the road as far as diagnostics are concerned. How far is the slave cylinder pushrod moving?
    Wulf likes this.
  10. Apr 28, 2023 at 12:55 PM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    OK, so things get even more interesting... I just went back out and tried again, now it's working just fine. In fact it shifts quite smoothly on a test drive.
    I'm wondering if this is going to be an intermittent issue.
  11. Apr 28, 2023 at 3:33 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I dunno what caused your little hiccup but my experience has always been that to try and get the hydraulic system working better has always led to replacing it. It's not expensive parts.
  12. Apr 28, 2023 at 4:47 PM
    rocknbil
    Bill
    In my case, before I saw the low level, when it was acting up I found if I pumped the clutch a couple times it would shift "sorta okay." I'd still flush/bleed the clutch fluid.
