Can someone accurately measure the height of a TRD Off Road?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OR4x4, May 29, 2019.
  1. May 29, 2019 at 10:33 AM
    OR4x4
    OR4x4 [OP] Well-Known Member
    Portland, OR
    2018 DCLB 4x4 TRD-OR Super White
    I need to know the height of a 100% stock TRD Off Road. Stock tires, stock leaf springs, stock shocks, etc.
    Toyota Corporate says 70.6” but I don’t know where they are measuring from.
    I am looking for the measurement from the ground to the highest point on the roof of the cab (not including the antenna). I can’t accurately get a measure, someone will likely need a square rule or something similar to get a square measurement of the height.
    I’m looking for a very accurate height measurement... thanks in advance.
  2. May 29, 2019 at 10:37 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Measurements will vary a bit between each Taco. Your best bet, if you are looking for something accurate, is to measure your own. Just use a step stool, measuring tape, and a level as a sight. If the level is level, your sighted measurement will be good to go.
    Here's a cheap lock level that would help simplify the task:
    https://www.amazon.com/dp/B000KKWQ9S
  3. May 29, 2019 at 10:40 AM
    OR4x4
    Portland, OR
    I will try as soon as I can. Just wondering what other TRD OR’s are sitting at. Going to have to make some decisions regarding garage clearance.
    tonered[QUOTED] likes this.
  4. May 29, 2019 at 10:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    The ground to the highest point of the roof.
    As @tonered says, each will slightly vary. Even air pressure in the tires, crooked surface it's sitting on, etc.
    If you are thinking of the parking garage/door opening, round up. Call it 72 and you should be fine. As long as the opening is 72 or more. :D
    tonered likes this.
  5. May 29, 2019 at 10:41 AM
    gemiv19
    gemiv19 Well-Known Member
    Ted
    Central Point OR
    2024 DCLB TRD OR Blue Crush
    Totally Stock for now
    Sitting Flat and Level 2019 TRD OR DCLB 4X4 is 70.5 inches tall to the roof line back of the cab. Ad 3 inches for the shark fin antennae.
  6. May 29, 2019 at 10:43 AM
    OR4x4
    Portland, OR
    This is 6” taller than Toyota Corporate states. Are you sure about this?
  7. May 29, 2019 at 10:49 AM
    gemiv19
    Ted
    Central Point OR
    Didn't type correctly. It is 70.5 lol
  8. May 29, 2019 at 10:58 AM
    OR4x4
    Portland, OR
    Phew, had me worried for a second.
    My issue is this:
    I am installing a GFC which adds 7.5” to the highest part of the roof (not including shark fin) OR 29” from the top of the bedside caps.
    My garage clearance is 7’ (84”).
    It sounds like I should be good. 72” (conservative measurement) plus 7.5” is only 79-80”. I should clear by about 4”. But if I don’t, I’ll be very very screwed.
  9. May 29, 2019 at 11:00 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Wouldn't it be easier to just park your truck under the garage door right now and measure the gap? o_O
  10. May 29, 2019 at 11:03 AM
    theandyj
    theandyj Well-Known Member
    Orange County, CA
    2019 Cement OR
    I had the same worry when I brought my TRD OR home. It clears my garage door at its lowest point just fine but my door is a little lower than normal.
    Remember to measure the lowest spot in your garage (typically the door near the opening) because the frame will be taller than the door in most standard setups.
  11. May 29, 2019 at 11:06 AM
    OR4x4
    Portland, OR
    It’s a garage I haven’t moved into yet, in another state. The best I can do is measure my truck when I get a chance.
    PNW/TRD Steve likes this.
  12. May 29, 2019 at 11:06 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
  13. May 29, 2019 at 11:07 AM
    paleh0rse
    Raleigh, NC
    Ok, that makes much more sense... good luck! :cheers:
    OR4x4[QUOTED][OP] likes this.
  14. May 29, 2019 at 11:09 AM
    OR4x4
    Portland, OR
    It’s an apartment complex parking garage. The marked clearance says 7’. So hopefully my 5-6” of extra clearance should be good enough.
  15. May 29, 2019 at 11:36 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just a note there that for whatever reason, most typical garage doors are set to not open fully, or simply can't because of the spring / cable setup. In both of our houses, I dialed in some more opening once I installed the garage door openers. In my case, I wanted the door frame to be the lowest point and the door completely out of the way.
  16. May 29, 2019 at 11:40 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Has anyone here factored in vehicle color for calculations?
    Your welcome.
    paleh0rse likes this.
  17. May 29, 2019 at 11:50 AM
    BingoBangoPickoMango
    BingoBangoPickoMango no no yeah
    Hawaii Nei
    2018 4X4 TRD Sport DCSB
    Another Bilstein Buildy Boi
    lol I remember stressin out about these measurements when planning my lift. I measured off a beam that was 78" tall, there was 4.5" to the top of my shark fin. So 73.5" total height including the shark fin. Idk the height of the shark fin off hand, so gotta go and measure that for yourself. Hope this helps
  18. May 29, 2019 at 5:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    Tacoma paint isn't thick enough to factor in.
