can someone confirm what this part is
Discussion in '1st Gen. Tacomas (1995-2004)' started by forbins, Feb 4, 2010.
  1. Feb 4, 2010 at 10:15 AM
    forbins
    forbins [OP] Well-Known Member
    2007 Double Cab TRD Off-Road
    is this my 4x4 actuator, or i've heard it called a '2-4 Shift Motor'
  2. Feb 4, 2010 at 10:23 AM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    electric pump maybe..?
  3. Feb 4, 2010 at 10:26 AM
    forbins
    pump?
    can anyone confirm that this is my actuator/shift motor?
  4. Feb 4, 2010 at 10:27 AM
    kroggy
    kroggy Well-Known Member
    Idaho Falls, ID
    04 TRD 3.4 4x4
    Grill Guard. PIAA 520's. And ...
    That is the transfer case actuator. Moves it from 4 hi to 4 low.
  5. Feb 4, 2010 at 10:48 AM
    forbins
    does this motor engage the 4x4 in Hi and Low??
    the problem with my truck is that the 4x4 doesn't engage, either in Hi or Low
  6. Feb 4, 2010 at 11:04 AM
    kroggy
    Idaho Falls, ID
    04 TRD 3.4 4x4
    Check this thread out!
    From the sounds of it I think your having trouble with the ADD Actuator.
    Check this thread.
  7. Feb 4, 2010 at 11:09 AM
    forbins
    dude, I started that thread, I acutally put on the ADD motor on the front diff and it's still not working, now they're saying it's the 'shift motor' mounted on my transfer case.
  8. Feb 4, 2010 at 5:57 PM
    kroggy
    Idaho Falls, ID
    04 TRD 3.4 4x4
    i wouldn't know then. do you have a 2-4 switch in the transfercase shifter or just the shifter. It may be one of those.
  9. Feb 8, 2010 at 5:46 AM
    forbins
  10. Feb 8, 2010 at 5:51 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  11. Feb 8, 2010 at 5:52 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    And can you fill your profile out, at least your truck specs?
  12. Feb 8, 2010 at 10:52 AM
    forbins
    thanks man, I filled in my truck specs.
    thanks for confirming that part, now the Toyota Stealership told me in order to get that 2-4 Shift Motor off the transfer case, I would have to open it up and undo some sort of clip, and that it doesn't simply unbolt and slide out. anybody know anything about this?
  13. Feb 8, 2010 at 11:02 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  14. Feb 8, 2010 at 11:05 AM
    forbins
    those are some nice write-ups, but that last one was for the shift lever, looking for a 'how-to' on getting the shift motor out.
  15. Feb 8, 2010 at 11:08 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It tells you how to get it out. Looks again at 2c.
  16. Feb 8, 2010 at 11:10 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    HHHmmmmmmmmmmm.............I may have read that wrong. Regardless, that's where it will disconnect internally. I can't find anything that goes into better detail.
  17. Feb 8, 2010 at 11:45 AM
    forbins
  18. Feb 8, 2010 at 11:51 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I saw that before, but I must have skipped over it. Hell, if you have to go that far you should replace all the seals too.
  19. Feb 8, 2010 at 12:11 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    HAHAHAH fail!
