Can someone explain Engine RPM's in relation to MPG?
Discussion in '4 Cylinder' started by Vrbas, Nov 29, 2010.
  1. Nov 29, 2010 at 6:51 PM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    ***This is in reference to Manual Tranmissions (i dunno, maybe it applies to automatics too but i think it's different).
    Alright, so i was always under the impression that the higher the RPMs the more fuel you are burning, thus the worse your gas mileage becomes. However, i've heard the side of the coin that states it's not about engine RPMs as much as it is "load". So does that mean that if i'm driving 40mph in 2nd gear at 4k RPMs @ 1/4 throttle that i'd be getting the same MPG if i were in 4th gear at 2k RPMs @ 3/4 throttle?
    Is that a good analogy? Or does anyone understand what i'm saying?
  2. Nov 29, 2010 at 7:05 PM
    TacomaTommy
    TacomaTommy Member
    JT
    Rocky Mountain Foothills, Alberta
    2006 SR5
    fogs, tonneau, hitch, gps, rims
    I have had a scangauge in my last 8 or 10 vehicles and in almost every condition on every vehicle the engine gets better mpg the slower it turns. The only exception is idling in gear or just off idle up to 1000 rpm or so. My 4cyl Tacoma is the same, downshifting at any speed, uphill, downhill, or whatever, lowers the mpg.
  3. Nov 29, 2010 at 7:07 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    More vroom vroom = more gulp gulp
  4. Nov 29, 2010 at 7:09 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    wow..........really??? e=mc yo
  5. Nov 29, 2010 at 7:11 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Hmmm... I actually get better gas mileage on my 2.7 with larger tires AFTER I regeared to 4.88s. My RPMs are always higher now. I'm at 3K rmp on the freeway and still get better gas mileage. I know alot come into play when bigger tires are put on so my scenario may be a little different. However, even tho i have higher rpms, my gas mileage has improved :)
  6. Nov 29, 2010 at 7:14 PM
    DWreck
    Derek
    Las Vegas, NV
    Squared!
  7. Nov 29, 2010 at 7:15 PM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    You get better mileage with higher RPMs because you changed the size of your tires.
    In general, the lower your RPMs, the better your mileage when dealing with stock or close to stock gear ratios (between engine and road).
  8. Nov 29, 2010 at 7:18 PM
    Vrbas
    Cause i got flamed in one forum trying to believe this. Granted, it was more of a 4cyl vs 6cyl thread. My statement was "4 cyl use less fuel than 6 cyl, therefore 4cyl > 6cyl gas mileage". And everyone lost their marbles on me saying that it takes more "load" to move a lower horsepower 4cyl than it does to push a 6cyl with more HP.
    My reasoning was "more cylinders = more fuel". I mean, am i wrong? Anyways, that was slightly off topic, but we did talk about engine load and how RPMs came into play and i was told that higher RPMs going up a hill is going to use less fuel than lower RPMs going up that same hill at the same speed.
  9. Nov 29, 2010 at 7:18 PM
    DWreck
    Derek
    Las Vegas, NV
    I think he did the gears with stock tires, then got bigger tires, which would improve over stock
  10. Nov 29, 2010 at 7:19 PM
    especk
    Erik
    Redding, CA
    It all depends on how hard the motor needs to work. Normally, turning higher rpms makes the motor work the hardest. But in the case of larger tires, the motor is actually working extra super hard to spin those tires so the gas mileage goes down. The lower gears make less work for the motor. Kind of like downshifiting on a mountain bike... it makes it easier to pedal and doesnt make ur legs work as hard
  11. Nov 29, 2010 at 7:19 PM
    especk
    Erik
    Redding, CA
    actually no. I had bigger tires for a while before I got the gears
  12. Nov 29, 2010 at 7:21 PM
    especk
    Erik
    Redding, CA
    With the bigger tires before the gears, my rpms were extra low and my mpgs were down
  13. Nov 29, 2010 at 7:23 PM
    especk
    Erik
    Redding, CA
    Most of the times this is absolutely correct. Just like my mountain bike example earlier
  14. Nov 29, 2010 at 7:27 PM
    DWreck
    Derek
    Las Vegas, NV
  15. Nov 30, 2010 at 12:04 AM
    TacomaTommy
    TacomaTommy Member
    JT
    2006 SR5
    On a stock vehicle that is totally INCORRECT. The lower the rpms the higher the mpg. The only time you need higher rpms is if you need to maintain speed, and that uses MORE fuel. This is easily measured.
  16. Nov 30, 2010 at 6:30 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Generally the best mpg is around 2000 rpm.....as a starting point. Next factor is th engines load if its lugging or revved too high ...yup, mpg goes down. My stock 245/75 tires get great mpg at 60 on the speedometer(standard 4 miles off so its 56 or so... another thread though) ,around 28 mpg , but at 70 on the speedo its more like 22 mpg. The drop isnt just wind resistance , but a combination with higher rpm.Youll need to do your own testing in the end for your specific setup , but between 2000 and 2700 is where i suspect most tacoma drivers fall for best mpg. You analogy of 4k vs 2k rpm and load , id say 4th gear is better than 2nd , loading the engine is often better. Consider the air volume you move , there is a ratio of fuel to that air. At 4000 rpm , you would do that for the power , that it may be lightly loaded is irrelevent to the fuel youll burn extra just spinning the engine at that speed.
  17. Nov 30, 2010 at 3:02 PM
    Vrbas
    So might I ask about shifting? Is it better to shift under 2.5k or should i move up my shifts to 3k for the first couple of gears?
    I usually shift at no more than 2.5k unless i'm in a hurry or something. Best bet to keep my shift points low?
  18. Dec 1, 2010 at 6:16 AM
    Tacoyota
    08 4wd
    no set rule , in general , shift at 2000 rpm when its flat or downhill and in no hurry.
    shift at 2500-3000 when flat , normal like driving. 3500 or so if on a hill. 2000 is sort of clumzy shifting on my 5 spd manual , i like 3000-3500 , very smooth there.
    Use the rpm's to your favor , th 4cyl needs to rev up some.
    Consider if you shift at 2500 on a hill and end up in the next gear at too low an rpm, thats why 3000-3500 works well , no harm in shifting and being around 2500 rpm in the next gear, in fact it might be ideal range to land into the next gear.
