Can someone explain Fuelly.com to me?
Discussion in 'Off-Topic Discussion' started by JCBigler, Dec 27, 2011.
  1. Dec 27, 2011 at 9:22 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Threads like this are just fuel for the fire, if you'll pardon my expression, when someone tells me they're getting unbelievably good, or bad, gas mileage.
    It's simple.
    If you want to know what gas mileage you're getting.
    1. You have to start with a full tank. Forget everything you ever knew about how many miles you've gone or how much gas you've ever used. Fill the effing' tank to FULL.
    2. Reset the trip odometer to zero.
    3. Drive. This part is easy. I hope.
    4. Somewhere around 300 miles, give or take, the tank's going to be near empty and it's going to be time to buy gas again. Drive into the gas station. Fill the tank. All the way full.
    5. Now, you just bought, say, 20 gallons. And your trip odometer says, say, 360 miles. Fine. You just used exactly 20 gallons to go exactly 360 miles. So you divide the number of miles on the trip odometer, (360) by the number of gallons you just put in the tank (20) and get 360/20 = 18mpg.
    6. Zero the trip odometer and repeat.
    Fuelly does exactly this except it keeps a running count of the "real" odometer reading, instead of zeroing the trip odometer every time.
    Suppose I did not fill the tank to full on that second fill - Hey, I can get some GREAT gas mileage. 360 miles divided by 5 gallons (the amount I put in the tank) = 72mpg!!! You have to fill to the same point - full - every time.
  2. Dec 27, 2011 at 9:24 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Don't confuse the huddled masses, man. :rolleyes:
  3. Dec 27, 2011 at 10:27 AM
    0BlackTaco6
    0BlackTaco6 Ive got tiger blood
    New Hampshire
    06 BSP DC SR5 4x4 6 speed
    Color matched and satoshi grille, hella 500ff behind, bhlm, sockmonkey bedsides, 17" sports 265/70 grabber at2's.
    Eureka!
  4. Dec 27, 2011 at 10:48 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Jesus Christ this isn't rocket science. You have no other way to know how much fuel you've used unless you fill up all the way (without OBD help). If you don't will up all the way, check the "partial fill up' box at the bottom. Because guess what, you only partially filled your tank. [​IMG] Fuelly will not factor in 'partial' fill ups into your average mpg.
    There's no 'future' anything about Fuelly. It uses the miles you just drove prior to fill up, and the amount of fuel used prior to fill up (based on filling up all the way). There has to be a constant in order to base fill ups on. Filling up all the way gives you this constant.
    This is the same way any person has calculated fuel mileage since the invention of the wheel. Not just the way Fuelly does it.
  5. Dec 27, 2011 at 11:05 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    So much derp
    Who woulda thunk entering the mileage the truck says and how many gallons the pump says into a computer could be so difficult
  6. Dec 27, 2011 at 11:12 AM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    I dont understand why this is so complicated, fuelly is extremely simple, you just have to always fill up, I never top off, always fill to the first click to keep things consistent.
    Say you fill up to the first click, drive 350 miles and at the next fill up your truck takes 18.5 gallons to the first click. You just drove 350 miles on 18.5 gallons of gas, hence your MPG will be 18.9189 MPG. This isn't rocket science and fuelly is not predicting anything, you just need to always fill up to the same level, if you dont there is no way to accurately calculate your MPGs offline.
    Sure this may not be 100% accuarate, but its pretty damn close.
  7. Dec 27, 2011 at 11:13 AM
    bgsmith
    Brian
    Hingham, MA
    +1
  8. Dec 27, 2011 at 11:16 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    What if I just used a calculator ?
    How does that work again , do I need to fill up all the way everytime ?
  9. Dec 27, 2011 at 11:43 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    :laughing:
  10. Dec 27, 2011 at 11:51 AM
    bgsmith
    Brian
    Hingham, MA
    First you need to make sure your calculator is topped off, be careful though, as most of them run on kerosene these days.
    If you can find one that runs on diesel grab it becasue they are rare, a little more expensive but they will run forever.
  11. Dec 27, 2011 at 11:53 AM
    Surferdude
    Surferdude Erich
    Erich
    Grayslake, il
    '11, DC SR5, 4x4
    ProEFX Tonneau cover, Coverking seat covers, Weathertech front floor liners, Coverking Cab Cover, Westin nerfs, in transit...
    I use Road Trip for the iPhone.
    You put in the ODO, gallons and price/gallon every time you fill, even partial.
    It does all the rest, duh.
    18.97mpg overall
    19.65 last fill.
    It also tracks maintenance costs, reminds you of pending future maintenance etc...
  12. Dec 27, 2011 at 11:58 AM
    OZ-T
    Peter North
    British Columbia
    If I use a paper and pen , do I need a new piece of paper each time ?
  13. Dec 27, 2011 at 11:58 AM
    OZ-T
    Peter North
    British Columbia
    Gas Cubby for Iphone is pretty similar
  14. Dec 27, 2011 at 12:02 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    You must fill the paper up completely, a partial filled paper will not give you accurate results .
  15. Dec 27, 2011 at 12:23 PM
    #35
    bgsmith
    Brian
    Hingham, MA
    And I wouldn't use a pen, what if you make mistake, you can't erase pen.
    Unless you get an erasable pen, but they smudge to easily then you get ink everywhere, this is getting more and more complicated, I need a nap.
  16. Dec 27, 2011 at 12:50 PM
    #36
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    If you use fuelly, it could predict your mistakes
  17. Dec 27, 2011 at 1:07 PM
    #37
    bgsmith
    Brian
    Hingham, MA
    Yeah, but how??
  18. Dec 27, 2011 at 1:22 PM
    #38
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Hell, I just use my calculator every few times I fill up. Much simpler.
  19. Dec 27, 2011 at 2:00 PM
    #39
    Mlrwerks
    Mlrwerks Well-Known Member
    Chicago Burbs
    '10 4X4 AC V6 Mag Gray AT
    UndercoverSE tonneau, backup camera, auto-dim mirror
    I believe how to compute a simple average is taught in 4th., maybe 5th. grade.
    Apparently a lot of the posters were absent that day. Geez!
    A sad statement on the status of the U.S. education system.
  20. Dec 27, 2011 at 4:38 PM
    #40
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Point out the "lot of posters" that can't compute an average.
    The OP certainly dreams that somehow Fuelly can know how many gallons he burned without filling up, but everyone else is saying he is delusional.
    Just a chance to ring in on the sad US education system while showing your lack of reading comprehension?
