can someone explain how cold weather kills MPG?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xGRIMEYx, Nov 16, 2019.
  1. Nov 16, 2019 at 12:27 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I just pull my polar bear out of the garage and ride it to work. Great mileage.
    Junkhead likes this.
  2. Nov 16, 2019 at 1:12 PM
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    Does a baby seal cost less than a gallon of gas? Asking for a friend.
    Speedfreak[QUOTED] likes this.
  3. Nov 16, 2019 at 1:18 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    physics
  4. Nov 16, 2019 at 1:27 PM
    DRansom
    DRansom Well-Known Member
    Newark, CA
    2018 Silver Tacoma TRD Sport 4 X 2
    In footballs, too.
    eurowner[QUOTED] likes this.
  5. Nov 16, 2019 at 2:30 PM
    VTbuckeye
    VTbuckeye Active Member
    Joseph
    Red 17 Tacoma TRDsport DCSB MT
    If it is 20 degrees on Monday and you get 14.5mpg and 60 degrees on Wednesday and you get 17.5 and you didn't fuel up between then it isn't the gas. All of the fluids are thicker and more resistant to flowing at cooler temps (engine oil, differential oil, hub greese). Your tires flex a little bit with each rotation and that takes more energy when the rubber is cold. The engine runs richer for longer as it takes more time to warm up when cooler. Just because your coolant reaches operating temp, does not mean all of the other fluids are at their ideal viscosity. After 30+ minutes most of the fluids are completely warm and the mpg is usually about the same (less air density changes, possibly tire rolling resistance changes) as warmer (more ideal) temperatures.
    xGRIMEYx[OP] and Pablo8 like this.
  6. Nov 16, 2019 at 2:39 PM
    jon.e.b3030
    jon.e.b3030 Well-Known Member
    john
    Don't forget, if you are running with defrost on the a.c. compressor is running to reduce humidity. Also are you going by the dash mpg? Not always accurate.
  7. Nov 16, 2019 at 3:04 PM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    Spinning an alternator by hand is not going to create the same resistance as the engine does. Doing it by hand does not create enough magnetic field to do squat.
    Go buy an old school crank megger and test it on a good circuit, note the resistance you can feel.
    Then go do the same thing on a short circuit (more draw) you can feel the difference in the energy required to crank.
    The only thing that changed was the current draw. (Load)
    You can also do the magnet down a copper pipe trick. Kids love it.
    Pablo8 likes this.
  8. Nov 16, 2019 at 4:12 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Very much agree with this. Absolutely true in cold places. All my point is, temps in the 60's, unchanged basically. Fill up with new gas and MPG goes from 19 to 17..........it is the gas.
  9. Nov 16, 2019 at 4:13 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Pretty much can do this with any hand generator set up.
  10. Nov 16, 2019 at 4:13 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Can we blame global warming?
  11. Nov 16, 2019 at 4:21 PM
    Taco_Turd
    Taco_Turd New Member
    Michael
    2017 Toyota Tacoma TRD Off Road
    Bone Stock
    You're spot on, colder air has more oxygen in it. Running in colder temps result in the O2 sensors sensing more oxygen thus using more fuel as the computer attempts to adjust the stoichiometric ratio. Warmer temperatures have less oxygen resulting in burning less fuel.
    Mopar Mussel[QUOTED] likes this.
  12. Nov 16, 2019 at 4:55 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Moving the non aerodynamic truck through denser air also.
  13. Nov 16, 2019 at 4:56 PM
    The_Devil
    E
    My biggest enemy is wind direction.
