Can someone give me a real world experience with 4.56 gear ratio running 35s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015trdoffroad559, Mar 23, 2023.
  1. Mar 23, 2023 at 10:06 AM
    2015trdoffroad559
    2015trdoffroad559 [OP] Member
    2015 toyota tacoma
    Alot
    I cant seem to find the answer I'm looking for anywhere. Please Help......
    Was it worth it?
    What highway mpg you're getting?
    would you do anything different if any?
    I have a double-cab AT
  2. Mar 23, 2023 at 10:25 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I am running 285/75/17 (about 33.5 on truck and on the ground) w/4.56. I went 4.56 as I felt it would be a good balance. I would also like to move to an Atlas with a 3.8 or 4.33 low. If I was to go up to 35's (probably 34 when mounted and on the ground) I would do 4.88's as the tire will also be heavier and likely wider, going to 35's means the balance of use would be even more towards offroad. As far as MPG goes at this point it is one thing no longer going to be used as a determining factor. But so far all highway (think Hwy15 Barstow to Vegas) I see about 15-16 at a steady 70-75mph.
  3. Mar 23, 2023 at 10:33 AM
    2015trdoffroad559
    2015 toyota tacoma
    Alot
    Thanks,
    I figure 4.56 because I spent most of the time on the Highway and go wheeling from time to time. I do tow a boat too. If I could get 15 or 16 going 70-75mpg im fine with that, better than what I get now. How did you do the regear and after everything how much was it total?
  4. Mar 23, 2023 at 11:58 AM
    01 dhrracer
    Still Shopping
    If you are spending most of your time on the highway I would reconsider doing 35's. Cost: I did front and rear with REM finished gears, front locker and a 10year warranty and hear in SoCal it was about $4600
  5. Mar 23, 2023 at 12:50 PM
    2015trdoffroad559
    2015 toyota tacoma
    Alot
    Wow... 4600 for front lockers too is not too bad. I been having 35s (34.7) to be accurate for a little while now just haven't done the regear. First I was looking into getting 4.88, but I seen posts that their rpm is high when doing about 70-75mph. I normally do 70 on highway, just want something more balanced with a little better performance offroad. If you had the option to redo your regear would you jump up to 4.88?
  6. Mar 23, 2023 at 1:16 PM
    01 dhrracer
    Still Shopping
    Not with the 285/75/17's. If I wanted to go 35's or 315/70/17's going to a lower gear would all be part of the decision to make the truck a more dedicated off roader. If I get to the point of wanting a dedicated off road rig I would do a completely different build and it would most likely not be a Tacoma.
    nd4spdbh and TnShooter like this.
  7. Mar 23, 2023 at 1:23 PM
    2015trdoffroad559
    2015 toyota tacoma
    Alot
    thanks for your feedback. It definitely helps
    TnShooter likes this.
  8. Mar 23, 2023 at 1:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    35's with 4.56's will spin right at 7% more rpms for the same mph than 3.73's and stock sized tires. So if it takes 2000rpms to go 65mph in top gear locked stock, it will take 2140 rpms for 4.56's and 35's so not much different.
    If you plan on getting 15-16mpg at 70-75 mph with 35's I got a great piece of land to sell you out in this beautiful place called the salton sea.
    Suicyco, Ricardo13x and Mully like this.
  9. Mar 23, 2023 at 2:00 PM
    2015trdoffroad559
    2015 toyota tacoma
    Alot
    haha.....I'm hoping to get 15-16mpg, I'm getting about 14 mpg doing 70 mpg on 35s with stock gearing, but mpg is not why I want to regear. Figures 4.56 would be closer to stock so that would be a better option for me.
  10. Mar 23, 2023 at 2:09 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    I'm getting 13.9mpg (mileage corrected via GPS) city/highway with 4.56, D-rated 35x10.5 Kendas, a full load of armor, and a 23" contractor shell. Probably would be a little higher if so much hadn't been mountain driving and/or I wasn't usually cruising at 75-80mph. Also guessing I'd get a half-MPG or more back without that shell, based on my experience going from a Softopper to it.
    edit: Nerdy shit! The calcs remove any intervals where I went wheeling/campin/etc from the overall City/Hwy MPG, because it'll artifically drive the number down.
  11. Mar 23, 2023 at 2:14 PM
    2015trdoffroad559
    2015 toyota tacoma
    Alot
    Are you happy with the 4.56 gears or would bump up to 4.88 if you was to do it over again?
  12. Mar 23, 2023 at 2:48 PM
    essjay
    Concord, CA
    I'm happier with 4.56 with the 35s than the skinny 33s, because my RPMs are lower at highway speeds. I imagine that I'd feel overgeared during "normal" highway driving with the 4.88s, just as I was with my old tires.
  13. Mar 23, 2023 at 2:54 PM
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    I'm on 35s E rated yokahama geolander MTs sitting around 6600-6900lbs (stupid heavy with front and rear bumpers, BAMF skids, drifter, spare tire, etc).
    I went with 4.88 for better gearing offroad. In hindsight, i would've been ok with 4.56 gearing for a better on-road experience. 4.88 isnt terrible but on longer drives going faster than 70-75 or keeping speed up a grade isn't the most fun experience. Its loud, uses up extra gas, and RPMs are higher than I like. Overall, 4.88 is great off-road but with as much highway driving I do (even just to/from trails), I would go 4.56 if i did it again.
  14. Mar 23, 2023 at 3:23 PM
    2015trdoffroad559
    2015 toyota tacoma
    Alot
    Thanks, that exactly the answer I was looking for. I just want a little better performance on highway and offroad. More highway of course. I appreciate all the feedback. I think I'm set on getting 4.56 ratio now. Just need that extra confirmation from the Community. Awesome!!
    Ricardo13x, essjay and rob1208 like this.
  15. Aug 11, 2023 at 12:17 AM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    How did it go?
