CAN SOMEONE HELP ME WITH BHLM IN SOCAL ASAP
Discussion in 'Lighting' started by shredtacoma, Aug 23, 2010.
  1. Aug 23, 2010 at 1:10 PM
    shredtacoma
    shredtacoma [OP] Well-Known Member
    Jace
    SOCAL
    07 Prerunner Debadged with snugtop
    Camburg lift, ProComp rims, Nitto Terragrappler tires, snugtop, Flowmaster exhaust and Airraid intake
    I need help with BHLM just did it put it in the oven and started prying it will not come apart. Maybe can someone help me in socal. I will pay. ASAP
    THANKS,
    JACE
  2. Aug 23, 2010 at 1:11 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    where in socal
  3. Aug 23, 2010 at 1:11 PM
    shredtacoma
    Jace
    SOCAL
    Huntington BEACH
  4. Aug 23, 2010 at 1:13 PM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    BEACH! haha
    anyway, i put mine in at 300 degrees (oven off after preheating) and used a flathead screwdriver to pry it. it doesn't come apart that easily. did you also take off the torx screws?
  5. Aug 23, 2010 at 1:14 PM
    shredtacoma
    Jace
    SOCAL
    yea it just wont come apart
  6. Aug 23, 2010 at 1:59 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Put it back in the over that is preheated for 325 now since it didnt work.
    Make sure its off when you place it back in. Use a towel to over the clear lens.
    Wait exactly 10 minutes. Use a timer.
    Take it out the oven. Have 2 Flat Heads Ready.
    Start @ the lower Corner of the headlight by the bumper and lower portion of the grille. Basically the lower left area. Pry it apart and pull it outwards and it has to come apart.
    Make sure you have moved the tabs outwards away from the clear tabs so you dont break them...
    Should work easily.
    As you go, youll have to pry it some more. Use the flat head to hold it in place and use the other one to pry while you're pulling
