Can someone overlook setup im about to purchase?
Discussion in 'Suspension' started by TimR, Aug 5, 2010.
  1. Aug 5, 2010 at 2:45 PM
    TimR
    TimR [OP] Well-Known Member
    Tim
    Vancouver, BC
    09 TRD Off Road Access Cab Black Sand Pearl
    Painted wheels black, 5100's, duratrac's, plasti dip fun, leer canopy, removed rear headrests, disabled seat belt alarm Satellite radio
    I have done a TON of searching for weeks, and figured out so much due to the knowledge many of you have added to this site - thank you! I just want to make sure this would work:
    '09 V6 access cab
    1. I want approx 2" lift in the front (OME 884) and rear TSB springs done -should this ride level? Will my rear sit too low when loaded up with a canopy, 140 lb aluminum boat, and a bed full of camping gear/beer :)?
    2. Should the OME 884 get me the 2" lift I need to level out the TSB? I also want to add OME shocks to all 4 corners.
    3. What do I specifically complain to the dealer in order to get the rear TSB springs done? Do they investigate, or just take my word? I am still under warranty.
    Thanks!
  2. Aug 5, 2010 at 3:35 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Tim,
    If your truck is a Canadian model it should already have the TSB springs installed from the factory. Only some models purchased in the States have the older 3 leaf packs still installed.
    I have an '09 SR5 access cab with an Arrow canopy. The rear springs have 4 leafs and have "MX" painted on them. They seem to be stiffer than the rear springs I had on my '07 offroad- which had the numbers of the 4 leaf TSB springs painted on them. Maybe the weight of the canopy makes it feel that way.
    I don't notice much sag from the canopy weight and the truck probably has a slightly higher back end than front. Overall, I like the way it rides and don't feel any need to level it.
    Good luck with your truck- I love mine!
  3. Aug 5, 2010 at 4:43 PM
    TimR
    Tim
    Vancouver, BC
    here is a photo of my rear springs. "MX" is written on the bottom of the lower spring. from doing a little searching, I believe that I must have the TSB springs. is this correct?
    My rear measures at 37 5/16" and my front at 34 5/16". (measuring fender flare at center of wheel)
    884 springs in the front should level it out nicely, right? and there is no need for ordering AAL's from toytec? I am adding OME shocks in the front, is it a good idea to do this in the back as well?
  4. Aug 5, 2010 at 5:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be good with the 884 springs. Personally, I would get teh Eibach 1.6" lift springs for the front. Then get the Bilstien 5100's all around. It would be a cheaper set up, with similar results (If not the same). Reason I say this, is because some people have gotten over 2" lift with the 884's.
  5. Aug 5, 2010 at 5:31 PM
    TimR
    Tim
    Vancouver, BC
    I do want more than 1.6" of lift though. I am ok if the 884's without spacers give me a bit more than 2", I just want to avoid allignment issues and having to buy uca's for $600.
    Lets say the 884's give me just over 2", would the TSB springs keep the back level with the front when the back is under a moderate load? I know no one knows for sure, but your guess is probably better than mine!
    Would you compare the TSB springs to a 1.5" AAL?
    Thanks guys!!!!!!!!
  6. Aug 5, 2010 at 5:49 PM
    84Hilux
    Gary
    Vancouver, Canada
    I got curious about this, so I went and measured my truck. I got 2 1/2" higher on the rear than the front. So, all else being equal, I assume that the canopy causes about an inch of sag in the rear compared to yours.
    Now I am wondering if I should level my truck- Help!! my truck spends more than my girlfriend!!!:eek:
  7. Aug 5, 2010 at 5:55 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Ucas, I second that. You may get away without them, but the overall driving feel and experience will be way better if you have aftermarket uca's.
    To give you some comparison. I have my front lifted 2.25" with Icon coilovers and the 1.5" aal in the back, and I am perfectly level.
    I would think that with 2" of lift in the front and the tsb or 1.5 aal in the back with a canopy, your back end would lower then the front of the truck and not look level.
  8. Aug 5, 2010 at 6:09 PM
    TimR
    Tim
    Vancouver, BC
    I have 3" of rake right now without the canopy installed. So I guess the canopy may lower it to 2.5 inches of rake, but when I have my 150lb jon boat and tons of camping gear in the back, you are probably right canadian boy, I may have a bit of sag if I add 2" to the front.
    I didn't know that stock uca's with a 2" lift would effect ride quality. If I need to end up getting after market uca's anyways, then screw the 2" lift, I'd get a full 3".
    Are there any decent uca's that will correct allignment that are NOT $600???
  9. Aug 5, 2010 at 6:17 PM
    TimR
    Tim
    Vancouver, BC
    I have 3" without a canopy, so it probably is causing you .5" sag.
    I hear you about the truck spending too much money - my advice would be to stop coming to this damn site. It is going to kill my bank account.:eek:
  10. Aug 5, 2010 at 6:18 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    i got 3" of lift with stock ucas and i got a good alignment
  11. Aug 5, 2010 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What do you consider "Good"?
