Can someone please clear up my concern??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SilkyTaco, Jul 17, 2020.
  1. Jul 17, 2020 at 5:27 PM
    SilkyTaco
    SilkyTaco [OP] Member
    Los Angeles County
    20'Tacoma TRD Off Road 6speed MT
    None
    Hello everyone!!
    I recently just got my Tacoma TRD Off Road 4x4 and I jumped the gun buy ordering my 4Runner TRD Pro Wheels 17x7, they are expected to arrive Monday. My biggest concern is, am I going to hinder the overall capabilities of my stock Tacoma by running the 265/70R17 tires? I am shortening the overall travel of the suspension right? Also would I be possibly rubbing when driving some more aggressive roads other than highways?.
    I also ordered an Open Country 2" inch leveling kit to avoid any rubbing but I have seen people with those installed and the front becomes higher than the back, I don't want that. Can anyone with the information
    I seek please give me some advice? Also don't really have the cash to do a full lift on it, I wanted to get away with the wheels and tires but not at the cost of losing stock performance.
    Sorry if I seem naive but this is my first Tacoma and I am already rushing into making purchases without thinking about the consequences first.
    Thanks in advance!!
    SilkyTaco
  2. Jul 17, 2020 at 5:31 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    You’ll be fine
  3. Jul 17, 2020 at 5:31 PM
    tcjacado
    tcjacado Well-Known Member
    2 inch in the front 1 inch in the back will be level.
    The wheels and tires are fine and no you are not reducing suspension travel, it may bump and rub a little, but still fully articulate.
    SilkyTaco[OP] likes this.
  4. Jul 17, 2020 at 5:39 PM
    SilkyTaco
    Los Angeles County
    None
    Damn I just seen that video LMAO I am guilty!
    tcjacado[QUOTED] likes this.
  5. Jul 17, 2020 at 6:06 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    more like 2” up front and level or slightly nose high, depending on your truck as each are different. That size tire will not rub, even without a lift. Might rub mud flaps slightly, but depends on your truck. You are not shortening the travel by adding tires/wheels.
    71tattooguy and tcjacado like this.
  6. Jul 18, 2020 at 1:28 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    You will be fine. I have 5100s with 2 inches in the front and a one inch block so you will not be level. You will have a slight to no rake at all. Its actually perfect, then I added the 265/70/17s Toyo at2s to the 4 runner pro wheels. No where even close to rubbing anything! Your fine with the lift or without.
    71tattooguy likes this.
  7. Jul 18, 2020 at 3:27 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    just add a 1" block to the rear, with your 2" front leveling kit. it will almost be exactly level. if you only lift the front, you will have the carolina/california reverse rake, with the front higher than the rear by an inch.
    i just did the same thing, 2" front, one inch rear spacer/block lift, from precision suspension. stock i was 35.5" front, 36.75" rear. after lift, i was 37.75 on 3 corners, 37.5 on the left rear (with a full tank of fuel, giving me a bit of a lean). good luck. Ski
  8. Jul 18, 2020 at 3:42 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    no problems
    SilkyTaco[QUOTED][OP] likes this.
  9. Jul 18, 2020 at 3:58 PM
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Return the damn lift kit and just run the wheels and tires for now. You’ll be fine
  10. Jul 18, 2020 at 7:04 PM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    you will be absolutely ok even in stock form. not even one bead of sweat will form from worrying lol.
  11. Jul 18, 2020 at 8:36 PM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    A leveling kit will cost you your stock performance. You may or may not feel the diminish in performance.
  12. Jul 19, 2020 at 5:18 AM
    VaToy
    Parts Unknown
    Mine didn't on both my Tacomas with 4runner pro wheels. I'm running 265/70/17 Toyo open country at2. The wheels move out about 1/2 inch away from the uca. Doesn't even come close to the mud guards. Lots of people have these wheels and tires size with no issues.
    Do you have personal knowledge and run these wheels and tires size?
  13. Jul 19, 2020 at 5:41 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I’m stock suspension On my Sport and had some rubbing on one wheel. I had to have my truck realigned, as it was in an accident prior, and I don’t think they aligned it when they fixed it. I still have a slight rub at times.
  14. Jul 19, 2020 at 4:00 PM
    VaToy
    Parts Unknown
    You must be the rare one.
  15. Jul 27, 2020 at 4:27 PM
    SilkyTaco
    Los Angeles County
    None
    Hey everyone well the only rubbinng issues I have were when braking and turning into a driveway, but it was only minor rubbing and now that the area has been shaved down by the tire itself it's all good now.
