Can someone tell me if something's missing?
Discussion in 'Solid Axle Suspension' started by Chrissmith, May 15, 2014.
  1. May 15, 2014 at 8:11 AM
    Chrissmith
    Chrissmith [OP] New Member
    Houston
    Tacoma
    Went off-loading and hit something hard. Took a look and it seems weird to have so much exposed like I see here. Am I missing anything?
  2. May 15, 2014 at 8:12 AM
    Chrissmith
    Houston
    Tacoma
    Another pic
  3. May 15, 2014 at 8:13 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Did you check your exhaust? Seems pretty low slung in the first pic. And even worse in the second.
  4. May 15, 2014 at 8:14 AM
    Chrissmith
    Houston
    Tacoma
    Yeah exhaust is hit hard, I was wondering about the housing?
  5. May 16, 2014 at 5:31 PM
    polack
    polack Well-Known Member
    Top pick looks like your leaking diff fluid out the wheel seal and splattering everything. Check your rear diff level and maybe it is brake fluid. Are your brakes working?
  6. May 16, 2014 at 5:36 PM
    Boone
    Boone, NC
    Airbags deployed
    It's wet. Water does that.
  7. May 17, 2014 at 9:33 PM
    nswsparky
    nswsparky Well-Known Member
    Chad
    Minnesota
    '03 TRD, SAS, ARB's F/R, Atlas 4 speed
    D44, SAS, 3 link coilovers, ARB's, Ford 8.8, Atlas 4 speed, cutting brakes.
    the yota axles have a lot of crap exposed.
  8. May 17, 2014 at 10:03 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    This
