Can someone tell me what the 4 next to Drive is?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dee_bo, Nov 15, 2009.
  1. Nov 15, 2009 at 6:01 PM
    dee_bo
    dee_bo [OP] Well-Known Member
    DFW
    2007 TRD Sport Tacoma
    None yet
    When you put the truck in drive you can also slide the shifter to the left to 4? What is that and why? Thanks
  2. Nov 15, 2009 at 6:04 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    4th Gear?
  3. Nov 15, 2009 at 6:05 PM
    BLKTRD6SP
    BLKTRD6SP Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    Just a guess as I have the 6 speed, but I would imagine that would be 4th gear. The auto is a 5 speed correct?
  4. Nov 15, 2009 at 6:07 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    uhhh...read the manual?
    In most automatic vehicles, any "number" denotes the highest gear that the transmission will go to, meaning it will shift automatically from first, second, etc. but will stop at the gear that you select. So if you have a 5 speed automatic, the four means it will shift all the way to 4th gear, and then stay there, even to the rev limiter.
    Otherwise, read the manual.
  5. Nov 15, 2009 at 6:09 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  6. Nov 15, 2009 at 6:10 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    is this a joke?:smack:
  7. Nov 15, 2009 at 6:10 PM
    dee_bo
    DFW
    None yet
    lol...hey I just got this truck. I'm coming from a 1998 frontier...give me a break..haha
  8. Nov 15, 2009 at 6:11 PM
    dee_bo
    DFW
    None yet
    I know the numbers mean gears but why is it next to D...just seemed odd to me
  9. Nov 15, 2009 at 6:12 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    manual recommends the use of 4th for towing
  10. Nov 15, 2009 at 6:13 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    easy to downshift when you need to i use it on big hills keeps the truck from hunting
  11. Nov 15, 2009 at 6:13 PM
    AK27
    AK27 Well-Known Member
    hmm its a gated shifter. push the shifter to the left of D and you will engage the 4th gear, shift down and get 3rd etc etc
  12. Nov 15, 2009 at 6:15 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    It's surprsing how often this gets asked, and suprising how many people have an answer that's totally wrong. sachou nailed it though ^^^
    A friend was driving my (auto trans) truck pulling a boat out of the water one time, he said that he put it into 3rd gear so the wheels wouldn't spin. Wrong on so many levels.
  13. Nov 15, 2009 at 6:22 PM
    xmixpixx
    xmixpixx Well-Known Member
    Lancaster, PA
    05 SR5 TRD Off Road 6 spd
    It is just like other vehicles where you have an o/d switch.. If it's a 5 seed tranny it'll keep it from shifting into overdrive where you have no torque when towing.. It keeps the tranny for searching for gears the whole time
  14. Nov 15, 2009 at 6:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    My truck seems to tow just fine in 5th gear. You still have torque in 5th.
  15. Nov 15, 2009 at 6:42 PM
    xmixpixx
    Lancaster, PA
    I'm just saying how, depending on gear ratios, torque is usually pretty poor in 5th, and if you're towing on hilly terrain any truck will search for gears more. I have a 6spd manual and when I'm towing our boat I rarely see 6th, but it's fairly hilly around us as well.
  16. Nov 15, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah....gotcha
  17. Nov 15, 2009 at 7:49 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Simply put "4" would be a shift pattern of gear 1-4, not using 5th gear. Likewise "2" would only allow 1-2nd gear or just 2nd only for winter driving on some types of autos, check the manual for that.
  18. Nov 15, 2009 at 9:22 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  19. Nov 15, 2009 at 9:27 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    whatever the gears are for, I like to usem to slow myself down when offroading downhill so my brakes dont heat up. Am I in the wrong here?
    :::flame shield activate:::
  20. Nov 15, 2009 at 9:29 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    Never ever put the shifter over to the 4! Doing so will rip a hole in time and space causing all matter to explode!!:boom:
