Can someone verify this assembly?
Discussion in 'Suspension' started by LonghornTaco, Oct 22, 2008.
  1. Oct 22, 2008 at 7:18 PM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I am about to compress my coils and mount the strut, but I have a couple of questions...
    1. Does this look right?
    Inner bushings
    Top plate with bushings
    Instructions
    If you notice in the instructions, there is another piece (indicated with the arrow) that I don't seem to have. I have two "kits", including the top plate and bushings for each side, and all of the nuts, bushings, etc... are in sealed bags. Neither kit had that piece. Also, that little silver sleeve (furthest to the left in the top picture) will probably fit, but it's gonna be tight and probably won't come off. That's why I wanted to verify this stuff before assembling the whole thing only to find it's wrong.
    2. Everyone here says that "stacking lifts" is bad. However, the instructions for the adjustable coilover state that I should set the 5100 to the .85" setting, unless I want less than 2" of lift, then set it to stock ride.
    Help! :eek:
  2. Oct 22, 2008 at 7:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Looks to be right. Your running a different top plate. As long as you have a bushing and backing plate under it, thats how it should be. :)
  3. Oct 22, 2008 at 7:24 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    The red arrow part...look at your dust boot on the shock.:)
  4. Oct 22, 2008 at 7:24 PM
    LonghornTaco
    Minnesota
    Thanks Chris!
  5. Oct 22, 2008 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, I thought he was talking about the bushing and the backing plate. :eek:
  6. Oct 22, 2008 at 7:27 PM
    LonghornTaco
    Minnesota
    I thought about that and took a look, but when I put that dust boot on, there isn't enough room left on the shaft to start threading the top bolt...
  7. Oct 22, 2008 at 7:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You'll be fine leaveing them off
  8. Oct 22, 2008 at 7:35 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    I don't remember if that part is also on the front.I am sure it's on the rear shock.That piece is supposed to be half way in the boot.
  9. Oct 22, 2008 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My rears have it, But I dont think I have ever seen it on the front. Generally, the front shocks dont have a rubber boot, as it can flex into the spring. They usually use a plastic "Dust cover" to protect from debrise.
  10. Oct 22, 2008 at 7:39 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    Correct, The front has a cap,dust cover.
  11. Oct 22, 2008 at 7:40 PM
    LonghornTaco
    Minnesota
    what about the strut height setting?
  12. Oct 22, 2008 at 7:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    How high are you looking to go?
  13. Oct 22, 2008 at 7:43 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    Read #13.kit instal
  14. Oct 22, 2008 at 7:44 PM
    LonghornTaco
    Minnesota
    The adjustable coilovers say they will adjust from 1.5" to 3.5". I wanted to go to the full 3.5". However, will setting this to .85 make me go to 4.35" or is the 3.5" supposed to be WITH the .85"?
  15. Oct 22, 2008 at 7:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you go to 3.5" wave "Bye bye" to your CV's
  16. Oct 22, 2008 at 7:47 PM
    LonghornTaco
    Minnesota
    Really? Does it increase the angle too much or something?
  17. Oct 22, 2008 at 7:47 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    You don't add in the .85. Ref the second line of the instal instruct.
  18. Oct 22, 2008 at 7:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. At 3" your pushing it. Above that, and carry extras
  19. Oct 22, 2008 at 7:48 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    You have the diff drop right??
  20. Oct 22, 2008 at 7:49 PM
    LonghornTaco
    Minnesota
    yep
