Can stock tires be replaced with larger ones ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by robinkm, Aug 22, 2009.
  1. Aug 22, 2009 at 8:03 PM
    robinkm
    robinkm [OP] New Member
    Kentucky
    Tacoma TRD 4X4
    I have a 2006 SR5 TRD 4X4 Crew Cab regular bed that is equipped with stock tires (265 / 70 / 16). Could anybody advise if I could go to a 285 /70 /16 without incurring tire rub. Is it possible to do this without a lift kit or any other change? The truck has had NO modifications. Thanks :confused::confused:
  2. Aug 22, 2009 at 8:08 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    You WILL rub at 285 without a lift.
    The max you can go without a lift is 265/75/16. ;)
  3. Aug 22, 2009 at 8:09 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    Not sure about the 285's, but I believe you can do the 265/75/16's...
    Hopefully, others will chime in...
    I went w/ the stock size b/c I live in the mountains can't afford any loss of power...
  4. Aug 22, 2009 at 8:21 PM
    robinkm
    Kentucky
    Tacoma TRD 4X4
    Good point......overlooked loss of power.
  5. Aug 22, 2009 at 8:24 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You aren't going to "lose power". I saw absolutely no difference of any kind in going with 265/75/16, including MPG.
  6. Aug 22, 2009 at 8:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. You dont "loose" power, but rather, decrease the leverage the tires have for transfering the torque of the engine into forward motion.
    :p
  7. Aug 22, 2009 at 8:31 PM
    TL697
    Jacksonville, FL
    It may not be noticeable, but it in fact does make a difference...
    And you are correct, you don't actually lose power motor wise, but the effective gear ratio does change...
    I'm waiting until I can afford lower gears, suspension lift, and rims and tires before I go bigger...
    Just sayin'
    It's science, not an opinion... ;)
