Can Tacoma alternator bearings be lubed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caslon, Dec 20, 2023.
  1. Dec 20, 2023 at 7:21 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Is there a nipple to do so or would it have to come out? I’m trying to pinpoint an intermittent grinding sound. It’s really hard to as the sound comes from the general engine compartment area.
  2. Dec 20, 2023 at 8:18 PM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    Bearings have to be removed from the alternator. There is no zerk fitting or means to lube it as the bearing has pressed metal sides. If this were on the 2 or 3rz, alternator removal is not easy.
    I'm hunting down a noise myself, but hadn't time to troubleshoot. You may loosen one belt at a time to determine which system is making noise. Good luck
  3. Dec 20, 2023 at 9:02 PM
    Caslon
    I’ll replace the belts along with the AC idler pulley. My belts need changing anyways as a prudent measure. If the intermittent grinding noise continues, I’ll move on to other possible causes. Sorry to say, I don’t have the luxury of doing all kinds of DIY procedures. Those days are long gone.
  4. Dec 20, 2023 at 9:08 PM
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    With the belt off you’ll be able to give the pulley a good spin and hopefully confirm if that is your issue. Alternator replacement, if necessary, is pretty easy and can be done without removing the other belts, should you need to do it another time.
  5. Dec 20, 2023 at 9:23 PM
    phoenix ray
    ray
    Phoenix AZ
    Also, at this age, there are replaceable idler pulleys with the AC and power steering belts. I just swapped out my 23 year old pulleys.
