Can the Block heater, oil heater, and battery blanket be wired together?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by winterpegtacoma, Feb 13, 2019.
  1. Feb 13, 2019 at 12:22 AM
    winterpegtacoma
    winterpegtacoma [OP] Member
    Silver 2013 Tacoma TRD
    - Volant cold air intake - Bilstein 5100 front shocks (2.5" lift) - Bilstein 5100 rear shocks (2" lift) -285/75/16 Goodyear Duratracs - Magnaflow catback exhaust
    I live in the Canadian Prairies so it's very cold here and I need to know if there's any way to have the Block heater, oil pan heater and battery blanket wired together so I don't need to have 3 cords plugged into a power bar and the power bar plugged into a power source. I just want something that looks clean installation wise. I don't have much knowledge with electrical.
    ValK83 and llamasmurf like this.
  2. Feb 13, 2019 at 5:24 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    If you have all of them plugged into a powerbar now, then sure. You just need to splice and solder. You might want to find out what the max amps of all the devices are and add them up. I suggest you have someone else do the work if you are not comfortable with electrical.
  3. Feb 13, 2019 at 5:56 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Damn that is a lot of 'keep the rig's fluids warm' equipment.
    What temperatures are you fending off with all this warmth armor?
    :popcorn:
  4. Feb 23, 2019 at 12:03 PM
    winterpegtacoma
    A few weeks ago it was -50°c with the windchill
    llamasmurf[QUOTED] and ajm like this.
  5. Feb 23, 2019 at 12:09 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  6. Feb 23, 2019 at 12:10 PM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    Good idea. Check the combined amps for sure. Many household outlets are 15 amps.
    When I lived in northern ND i remember the cheap extension cords breaking in my hand at really cold temps. Had to buy a $50 cord.
    llamasmurf likes this.
  7. Feb 23, 2019 at 9:06 PM
    Biodegradable
    Biodegradable Well-Known Member
    Winnipeg
    10 4x4 SR5 DBLC LB
    ALL-PRO Skid, Nokian R-SUV winters, weather tech, bak flip fibermax
    Jeez you are giving us peggers a bad name, it was only -40C (-40F) btw, windchill doesn’t affect vehicles
    If you want to burn down your truck use a battery blanket.
    That was the only day I plugged my truck in - in 3 years, started great!!!!!! On the -35C day though it barely started unplugged, so I knew not to push it.
    Now if you are oil panning it as well - you won’t need anything else.
    Use synthetic oil.
    If you have money to burn get one of those AGM 31 (1100+ cold cranking amps) - you’ll be able to power the Spike in Transcona during an outtage!!
