Can the dealer change tire size settings?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flash1034, Nov 27, 2018.
  1. Nov 28, 2018 at 2:37 PM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    I did some internet searching before spending the $250 for the Hypertech calibration module. It was driving me up the wall, even if it was only a few percent off :rofl:
  2. Nov 28, 2018 at 3:22 PM
    Flash1034
    Flash1034 [OP] Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Awesome info. Thanks for the response!
    1bad2k[QUOTED] likes this.
  3. Nov 28, 2018 at 3:27 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    That's only for the navigation. Doesn't affect the speedometer at all.
    beergeek likes this.
  4. Nov 28, 2018 at 3:28 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    best thing I found so far was hypertech which does an inline correction. The computer still see the off nummber but at least your speedo is correct. I compare it to gps for correct speed to ensure.
  5. Nov 28, 2018 at 3:31 PM
    nudavinci64
    Robert
    That was me after awhile I caved. worked great for tire change. It has been off with gear and tire change. Need to figure that out.
  6. Nov 28, 2018 at 3:42 PM
    TacoPharm
    Phil
    San Diego
    Just have to pull it out again, the app used to calibrate the sender has a section for gear changes too :thumbsup:
  7. Nov 28, 2018 at 3:45 PM
    nudavinci64
    Robert
    Oh I know that. I mean I input the gear changes and tire changes into the settings and it was not correct (actually off 10mph). When I did only the tire change it was spot on.. I need to map it out and see whats the issue.
    Also I guess tip so you don't have to pull it out is leave the USB attached and have the end coiled or available under the dash. That is what I did so I do not have to remove the dash to make any updates. I knew I was going to regear at some point and still have plans for larger tires next round.
  8. Nov 28, 2018 at 4:17 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Why would the navigation be concerned with tires at all if it uses GPS?
  9. Nov 28, 2018 at 4:26 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Just a quick FYI for anyone considering larger tires... I am getting 255/80/17 Copper ST Maxx installed this weekend. I am currently running 275/70/17 BFG KO2s and will be keeping them for resale. They have approximately 30k miles on them but have a lot of tread left. They still look pretty much new but I just want to try out the pizza cutters. Anyone interested let me know. Looking to get around $300 for all four tires.
  10. Nov 28, 2018 at 4:34 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    It's off enough to make me what to correct it. I thought Toyota's have incredible accurate speedo due to their fancy Speed Sensors.
  11. Nov 28, 2018 at 4:36 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    Not sure the science behind it, but it did NOT work for me, @mesojdm nor @SearArtist
  12. Nov 28, 2018 at 4:37 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Yep. The head unit trick does not work.
    Bought a hyper tech because I believe in having an accurate speedo, odo, and mpg.
  13. Nov 28, 2018 at 4:49 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    You only use it once to fix and then unplug it right? Would you be willing to sell it? I'm surprised no one on the forums have started a "rental" service like they have for the ECGS tool.
  14. Nov 28, 2018 at 4:51 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    Also, some said it takes some driving after doing the head unit "calibration" for it to correct. I did it 3 months ago when I got my tires put on and I just went out for a quick drive to test it for you and can confirm that when the speedometer on my truck reads 60, the GPS says I'm actually doing 63. That's with 32.2" tires.
  15. Nov 28, 2018 at 5:26 PM
    #35
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    No it stays plugged in behind the gauge cluster.
  16. Nov 28, 2018 at 6:33 PM
    #36
    Flash1034
    N/W Montana
    Nice Hijack
  17. Nov 28, 2018 at 7:47 PM
    #37
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    :anonymous:
    Sorry... I’ll move along now...
  18. Jan 5, 2021 at 11:05 AM
    #38
    Matthewl0799
    Matthewl0799 New Member
    2021 Tacoma SR5
    Old thread but, that hypertech tool could be used for odometer fraud. Also, just putting a 1" larger tire on your truck is off 2mph @ 60mph, so a truck that's been running that oversized tire for 100K miles would read about 3,300 miles under actual mileage on the odometer....not a huge concern, but think about the guys going up 3"+ diameter.
  19. Jan 5, 2021 at 1:21 PM
    #39
    nudavinci64
    Robert
    if you leave the USB plugged in you can run the other end under the dash if you ever need to adjust it again. I have mine setup that way and have used it a few times to adjust with tires, gearing etc. Quick change instead of pulling the dash apart each time.
  20. Jan 9, 2021 at 9:14 AM
    #40
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    Every Japanese brand motorcycle and pickup truck I have owned read around 4 to 6% lower than actual MPH. The tire change might get you right on the spot. Back in the day before GPS you placed the vehicle on cruise at 60 mph and you started a stopwatch when you passed a mile marker. When you pass the second mile marker your stopwatch should be at 60 seconds.
