Can the dealer look up service history?
Discussion in 'Technical Chat' started by notslow, Apr 19, 2009.
  1. Apr 19, 2009 at 4:24 PM
    notslow
    notslow [OP] Well-Known Member
    Palm Springs, Ca.
    02 TRD black
    Hey guys,
    I always got a question when I post :eek:
    I know with certain auto brands the dealer can look up the service record of their vehicles as long as the work was done by any dealer. Does Toyota do this? I would like to find out what work has been done on my Tacoma before I got it. I know the T belt is done because the sticker is on the cover, but I'm not sure if they did plugs or other maintenance. If I can't find out I'll just do the shotgun method and replace everything that should be replaced by now.
    Thanks, Will
  2. Apr 19, 2009 at 4:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If the work was performed at a Dealer, then, yes. They can look it up.
  3. Apr 19, 2009 at 5:06 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    That was fast, thanks Chris. I'll call the dealer tomorrow.
  4. Apr 28, 2009 at 2:46 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    An update,
    I called the local dealer. They said they can only look up work that they did. There is no national database. It was nice to go in to the BMW dealer and get a printout of all sevice done on my 325i, though it showed to be due for maintenance too. So I guess I'm back to replacing things that might be due for replacement based on mileage.
    Will
  5. Apr 28, 2009 at 3:00 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Carfax gives a decent history on most vehicles if the dealer reports it. I know my history lists all dealer visits.
  6. Apr 28, 2009 at 5:10 PM
    2toys
    2toys Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    Can I suggest you call another dealer? I have retrieved toyota dealer(s) work performed on my used corolla. It was from differing dealerships. The dealer retrieved this info from the VIN. I was there in person and it took them all of 5 minutes.
  7. Apr 28, 2009 at 5:30 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    If you are looking for service records for your truck then the servicing dealer will be the only to have a record of the repair’s each dealership is independently owed and not linked up. If you are looking for warranty repair’s any dealer should be able to look them with no problem.
  8. Apr 29, 2009 at 5:31 PM
    notslow
    Palm Springs, Ca.
    02 TRD black
    Thanks guys, but I'm just going to change the plugs, fuel filter, brake fluid ( I can see that 's never been done) What else should I do? Rear diff? I have the locker. I already put in a new AFE filter.
    Will
  9. Apr 29, 2009 at 6:35 PM
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
    That is exactly correct
    Service work can only be pulled by the dealer that preformed the service. Warranty work can be pulled by any dealer.
