Can the fuel gauge be made to work with a fuel cell?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, May 18, 2024.
  1. May 18, 2024 at 5:01 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I'm considering swapping out my gas tank for a large fuel cell. I don't have smog where I live. I have 2 questions.
    • Can the fuel gauge in the 3rd gen (2018) still be made to work with a fuel cell?
    • Is there any way to trick the range display on the dash to reflect the new tank size? e.g. a 40gal tank showing ~600 miles when full.
  2. May 18, 2024 at 5:09 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yes, very easy to do. Just don't cut the red wire!
  3. May 18, 2024 at 5:25 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    "A fuel cell is a device that generates electricity through an electrochemical reaction, not combustion. In a fuel cell, hydrogen and oxygen are combined to generate electricity, heat, and water."
  4. May 18, 2024 at 5:54 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Unless you use common sense and google gasoline fuel cell. Use your head man…..
  5. May 18, 2024 at 6:08 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
  6. May 18, 2024 at 7:04 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    I'm not trying to attack you or your inquiry. It's the term "Fuel Cell" that's been bastardized by the hotrod industry to include almost any aftermarket tank. And that's all they are, aftermarket gas tanks. Ideally you want one that's the same depth as the toyota tank and accepts the toyota fuel pump sending assy.
  7. May 18, 2024 at 7:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Suspect that is an ECU thing. If right, you'd have to change the capacity side of the equation in the ECU. Maybe one of the tuners have figured that out?
  8. May 18, 2024 at 7:35 AM
    soggyBottom
    My understanding was that gasoline fuel cells have bladders, gas tanks don't. There are a few other differences but that is the main difference.
    There are definitely some benefits to using the stock fuel pump assembly.
  9. May 18, 2024 at 8:09 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Holy H2!!!
    - I thought when reading the heading...
    but then thought - no way... Not on this board! This is just talk of a replacement fuel tank...
    Probably. It should be just a level sensor...
    Probably more trouble than it is worth unless the tuners have access to the actual calculation for the range as Bill mentioned above.
    Hopefully, it is an easy factor (21 or 22 to 40 gals is a factor of 2x) and you can do the math in your head. It's not as if the range is so accurate - or precise anyway.
  10. May 18, 2024 at 8:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    That is true for safety reasons in race applications. In that world they aren't just a 'custom tank'.
  11. May 18, 2024 at 8:42 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I would think the fuel gauge would read pretty accurately, it’s just reading the proportion of tank that is full, it isn’t reading the exact number of gallons.
    SH10151 likes this.
  12. May 18, 2024 at 8:45 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Harmon or Jazz should be able to make a cell or “tank” that has a custom bulkhead of the OEM fuel pump and sender. The cell would also most likely be semi-custom depending on how you mount it.
    I’d give them a call.
    For fuel range, that would be a tuning thing with the ECU or dash itself if possible from the god @JustDSM .
  13. May 18, 2024 at 8:53 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Things were easier back when you could still buy an oversize Australian tank, but I think the regulations have shrunk their tanks as well.
  14. May 18, 2024 at 8:57 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    The Ultragauge can show you distance to empty, and I'm sure other code reader type gauges can do the same, so I would just get one of those if that number is important to you.
    Personally, I'd go with the old school approach: reset trip meter when refilling, and watch the miles vs. gas gauge (assuming that is easier to get to work).
    SH10151 likes this.
  15. May 18, 2024 at 9:27 AM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    shotgunbilly420 likes this.
  16. May 18, 2024 at 10:41 AM
    turkeyslayer66
    turkeyslayer66 Well-Known Member
    mike
    22 AG Trd Sport
    Fuel cells have been around a lot longer than any alternative new wave energy definitions.They are different than gas tanks, as they are designed to be foam filled or equipped with a bladder to contain fuel and vapor in event of a crash or rollover. Fill and vents are designed to also keep fuel from leaking out. I get what your saying, but if you ask someone about fuel cells, they are going to assume you are talking about liquid fuel containers for automotive racing use.
    soggyBottom[OP] and BillF1564 like this.
  17. May 18, 2024 at 11:18 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    What do you mean by "fuel cell?"
    To me, that's a that's a lined tank filled with foam.
    Limited lifespan. Not intended to be filled at all times.
    BillF1564 likes this.
  18. May 18, 2024 at 11:34 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    OZ TRD, Chew, HiBillyMaysHere and 2 others like this.
  19. May 18, 2024 at 1:19 PM
    soggyBottom
    Yep, that's the one.
  20. May 18, 2024 at 7:07 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    1) yes its pretty easy. All you need to know is the ohm range from full to empty on a factory fuel level sensor and get a same ohm range one for your aftermarket fuel tank.
    2) maybe? You would need to know how it calculates fuel usage. If it uses injector pulse or maf it won't work but if it uses fuel level percentage over miles it'll work from the factory you'll just a really high mpg.
