can the rear end (diff carrier/axles/wheels) be adjusted side to side?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by builthatch, Feb 2, 2011.
  1. Feb 2, 2011 at 7:51 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    to shift the entire thing left or right, wheels and all?
  2. Feb 2, 2011 at 7:52 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yes...A little...but why??
  3. Feb 2, 2011 at 7:55 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    i figured as much, thanks.
    yeah i was just curious about the relationship of adjustment of the rear, vs. the bed, vs. the cab.
  4. Feb 2, 2011 at 7:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check your U-bolts and make sure the leaf springs are on the spring perches. They shoudn't shift at all aside from normal suspension movement.
  5. Feb 2, 2011 at 7:58 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Anythign can be moved with a big enough hammer ;)
    but not really.
  6. Feb 2, 2011 at 7:59 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig...
    also check for a broken or bent centering pin.....happened to me.
  7. Feb 2, 2011 at 8:01 PM
    jandrews
    '09 FourDubDee TRD OR
    Still flipping out over your bed being uneven huh?
  8. Feb 2, 2011 at 8:16 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    yeah i was thinking if i tail slid hard enough into a curb i could probably move it over a bit. easier than a hammer IMO.
    haha, nah i'm actually fine with it because i've studied other trucks that have the same deal, HOWEVER...
    what confuses me is, ok...
    the bed is off to the passenger side a bit vs. the cab. but passenger mud flap outer edge is closer to the outer plane of the passenger side tire than on the other side.
    so that means if i were to correct the bed vs. the cab, then the wheels would be even more off vs. the bed sides/flaps!
    i'd think the constant should be the cab, right? so if the bed can be adjusted, i was thinking maybe the rear can be adjusted, but apparently is can't to the degree where it would fix this.
    but srsly, it's more of a curious thing than a worry - i've spent quite a bit of time looking like a truck stalker the past couple weeks, standing behind trucks and eyeing shit up. i was even doing it at the phila int'l auto show, haha.
  9. Feb 2, 2011 at 8:23 PM
    jandrews
    Take mudflaps off. Problem solved.
