Can Third Gen Coilovers Fit First Gen? '04 Taco Double Cab 2wd Prerunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by khughes968, Feb 21, 2022.
  1. Feb 21, 2022 at 12:20 PM
    khughes968
    khughes968 [OP] Well-Known Member
    Kenneth
    2004 Red Tacoma DoubleCab 2.7
    Hey Everyone,
    I really need new front coilover's bad. My buddy has OEM coilovers from his 2018 tacoma he replaced for aftermarket ones, and his only have about 20,000 miles on them. He said that he would give them to me, and we tried to get them to fit, but the holes were too wide for my first gen taco.
    Is there any way that we can do any sort of modification to make them fit? Any help would be appreciated as it would save me the cost of getting new coilovers.
  2. Feb 21, 2022 at 3:23 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Are you in CA bay area by any chance?
  3. Feb 21, 2022 at 3:40 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    While I haven't put my hands on 3rd gen coilovers, the likely answer is no.
    Your best bet is to get yourself some new Bilstein 4600 shocks. If you also need new springs I believe 880's are the stock height.
  4. Feb 21, 2022 at 3:43 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    They won't bolt right in, no. The amount of work to make them fit...you'd be better off just buying some cheap aftermarket replacements from Monroe or something.
    JasonLee likes this.
  5. Feb 21, 2022 at 5:01 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I am guessing you lack the skills at this time to make them work??
    Paying some one it is much cheaper to buy the correct parts Ball park figure an easy $300.00 or more for both sides plus alignment.
  6. Feb 22, 2022 at 6:32 AM
    khughes968
    Kenneth
    I'm in SW Florida, unfortunately.
  7. Feb 22, 2022 at 6:33 AM
    khughes968
    Kenneth
    How much work, if we were to go ahead and mod it to fit, would it take? I appreciate your initial response but a general ballpark would be awesome too :D
  8. Feb 22, 2022 at 6:41 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I don’t think you’ll get a good answer - it’s not worth the work to run stock parts so nobody considers it. Without parts and truck in hand to look at, I can’t even be sure it could be done.
    Black DOG Lila, eon_blue and Bivouac like this.
  9. Feb 22, 2022 at 7:45 AM
    eon_blue
    Azusa, CA
    The top hat bolts aren't gonna line up for one thing, and I'm not even really sure they use the same 3 bolt top hat mounting that we do. You will have to look at the coilovers and see what would need to be done.
    But @0xDEADBEEF is right, it's a lot work for something that's not even really an upgrade and might not even be possible in the end.
  10. Feb 22, 2022 at 7:47 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I'm not even sure where to begin something like that- You'd either have to modify the coilover itself or the truck. Modifying the truck would be rather destructive, would require donor coil towers from a junkyard truck, no guarantee that the resulting suspension geometry would work, etc.. I don't know what you'd have to change on the coilover- it's not like you can just make it shorter or longer and then somehow attach a 1st top cap to it.. It's just a bad idea the whole way around, and ultimately you're not gaining anything. You'd have a wrecked truck or a wrecked coilover.
    If you need something today and don't have any money, Monroe makes a "strut assembly" - a shock and coil spring you can just swap in there. They aren't known to be great quality, and the last few times I've heard of people trying them, they haven't been happy with height of the truck afterwards. IIRC they sit like 1" lower. People were trying to get the same part but for a 4runner but I think had the same results (which isn't surprising).
    If you can wait a couple of days- you can get Bilstein 4600s. If you just get the shock- you'll need a shop to compress the coil spring and swap the shock for you. Or you can get the shock, a new coil, and the top cap separately and still have the shop assemble all that for you, and just swap them in. This is likely your best option, IMO.
    eon_blue likes this.
  11. Feb 22, 2022 at 7:49 AM
    eon_blue
    Azusa, CA
    Andy01DblCabTacoma likes this.
  12. Feb 22, 2022 at 8:17 AM
    khughes968
    Kenneth
    Sounds good thanks for the info. I was thinking that I could just swap the strut mount from a third gen, and then put the third gen coilovers right in there. Or, are you saying that I would have to get the things that the coilovers attach to out of a junkyard and then somehow weld it on/bolt it into where the old ones used to be, and then put the third gen coilovers in? And you are saying that the ride quality might be f***ed up because of all the modifications? Sorry again about the request for more info but this is helping me learn about suspension and make an informed decision on how to move forward
  13. Feb 22, 2022 at 8:26 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Post pics side by side of the suspension setups. That will help determine what needs to be done.
    If the 3g setup bolts up to the LCA the same as the existing coilover then half your battle is over and you can try just swapping the top hat over.
    As others have said though, probably be happier just grabbing some Bilstein 4600's and slapping them on. They're cheap and ride pretty great. Not to mention the 3g is heavier so the 700lb coil spring that comes on them will likely not ride very comfortably unless you have considerable weight up front on your 1g.
  14. Feb 22, 2022 at 8:43 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Tacoma's have coilovers. Struts, while similar, are a different type of suspension component. (See this link for the difference).
    The coilover towers/mounts are welded to the frame. So you'd be cutting them off and getting 3rd from a donor truck. That's no small modification, and would be way more costly than a proper set of 1st gen coilovers. You'd be pulling the engine out, etc.. just to get to the inside of the frame rails. It's not impossible, but if I was cutting all the front suspension components off, I sure as hell wouldn't be installing 3rd gen IFS components- I'd either be swapping a solid axle in, or some other custom solution.
    This is also an excellent point. For reference (OP) the stock 1st gen coilovers are like 550 or 600. At least the most aftermarket adjustable coilovers (Kings, etc...) are 600 lbs.
    There are an overwhelming multitude of reasons not to do something like this.
  15. Feb 22, 2022 at 8:47 AM
    khughes968
    Kenneth
    Awesome Andy, thanks so much for all your information. That is what I was looking for. And like you said, modifying the coilover would probably cause serious damage to it. thanks for all the info. I wish it fit :(
  16. Feb 22, 2022 at 8:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    Lets keep it simple.
    No.
    Some deductive logic.
    2nd & 3rd gens do interchange. If 3rd's would fit on 1st's, that means 2nd's would fit on 1st's too.
    Since 2nd's had a 10 yr run and no one around here has put them on 1st gens, that begs the question why.
    Answers given above. Not worth it.
    Kevins60 likes this.
  17. Feb 22, 2022 at 8:54 AM
    khughes968
    Kenneth
    Hey you are in Largo! I'm down in Sarasota. Do you have any spare gen 1 parts or any toyota tacoma contacts/places where I can get work done?
  18. Feb 22, 2022 at 9:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    Never owned a 1st gen. so no parts. And my 2nd gen is just a poor mans 5 lug.
    What kind of work?
    I don't have any shops that are Toyota specific, but do have some other places I've suggested to folks for various tasks. Although I'd think Sarasota area would have a good bit of the same these days.
  19. Feb 22, 2022 at 9:25 AM
    khughes968
    Kenneth
  20. Feb 22, 2022 at 9:25 AM
    khughes968
    Kenneth
    Also Andy, what do you think of these?https://gainesville.craigslist.org/pts/d/gainesville-tacoma-front-struts/7430357480.html they are stock, I would probably remove the lift spacer.
