Can TPMS be bypassed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spruce Juice, May 26, 2012.
  1. Dec 26, 2012 at 10:50 AM
    #81
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    PVC
  2. Dec 26, 2012 at 10:50 AM
    #82
    OZ-T
    Peter North
    British Columbia
    How many times do cops search under or behind the seats ?
  3. Dec 26, 2012 at 10:52 AM
    #83
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Well in my truck just about every time they pull me over.
    Could be the weed smell :notsure:
  4. Dec 26, 2012 at 11:24 AM
    #84
    OZ-T
    Peter North
    British Columbia
    Your truck moves ?
  5. Dec 26, 2012 at 11:36 AM
    #85
    XXXX
    sKiP
    05 Prius
    Yep. Just sounds like it's going to explode when I run it. Had it out last weekend for some 4x4. I have only driven it 3 times in the past 2-3 months.
  6. Dec 26, 2012 at 11:54 AM
    #86
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I have my Scanguage covering up the light on the dash..don't even know its there.
  7. Dec 26, 2012 at 12:10 PM
    #87
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I hacked my 2010 Yaris TPMS module, and cut one lead and
    soldered to another, installed a switch
    when running my TPMS wheels, I turn it on...works like the gubmint wants it to
    when running wheels without TPMS, I flip the switch and the light on the
    dash goes away, and all my VSC and TRAC still works. works sweet.
    I do not know if I can make this work on
    a tacoma, but when I get my 2013 tacoma soon, I will deep-dive and see
    if the same switch can be slapped in
    http://www.yarisworld.com/forums/showthread.php?t=11058 jump to post 115
  8. Dec 26, 2012 at 12:12 PM
    #88
    jassco
    jassco Well-Known Member
    Boston
    2010 Access Cab 2.7L SR5 5spd, 4x4
    5100 set to .85 w/ rear TSB, 2012 Rear-view Mirror, Grillecraft, Team Trails FJ Wheels, TPMS canister, Rear headrest delete, Rear console delete, Valley Hitch, Frame undercoat, $2.99 Tailgate hose clamp lock, Avid light bar, 4x4 lighted switch ala Biceman.
    I've had my pvc canister in the little cubby in the bed for 2 solid winters. I haven't had to add any air yet. For $5 is failing after a few years even a valid concern?:rolleyes:
  9. Dec 26, 2012 at 7:11 PM
    #89
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I just deal with the light. Don't bother me!
  10. Feb 20, 2013 at 11:03 AM
    #90
    Scott2006
    Scott2006 Active Member
    La Mesa Ca.
    Tacoma PreRunner
    I spend a lot of time in Baja and my Spanish isn't good enough to explain what that pipe thing is. I got a nice little lady bug sticker from my grand daughter and fixed the problem... :D
  11. Feb 20, 2013 at 11:10 AM
    #91
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    i could not get mine to work with steel nipples and caps.
    Switched to PVC and it worked fine.
  12. Feb 20, 2013 at 11:42 AM
    #92
    biglinc
    biglinc Well-Known Member
    linc
    maine
    07 tacoma
    I removed the cluster and took a tiny piece of electrical tape and placed it under the thin plastic cover and over the hole where the light is,one piece up one piece down , this hides the light and is very easy to do , its reversable and you only have to peal the black cover back and remove the clear plastic shell, you can do it without removing the needles, just be carfull not to cover up part of your turn signal arrow, ask me how I know this, this whole operation only took about 15 minutes max ,the gauge cluster comes out very easy , I have done this on lots of vehicals in the past mostly the check engine light but also the tpms, the best part of this mod is that you cannot even tell there is any tape or any problem with the system , I don't need O'bama telling when I've got a flat!!
  13. Feb 20, 2013 at 11:44 AM
    #93
    biglinc
    linc
    maine
    07 tacoma
    if anybody does this mod they should take some pitures , I should have!!
