Can u put 22r in v6
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bear4x4, Mar 9, 2019.
  1. Mar 9, 2019 at 7:08 PM
    Bear4x4
    Bear4x4 [OP] Active Member
    1997 flat bed toy
    Want do you have to do to put 22r in to replace blowed v6 found truck that needs engine might buy it if not hard to do
  2. Mar 9, 2019 at 7:18 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Lots of fab work, ecu, transmission or adapters. Probably alot of other stuff. Oh and lots of $$$
    TacomaJunkie8691 likes this.
  3. Mar 9, 2019 at 7:18 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Do you happen to have a 22r laying around or something? Dunno why anyone would want that engine in a truck, no horsepower at all.
    TacomaJunkie8691 and Sperrunner like this.
  4. Mar 9, 2019 at 7:22 PM
    Bear4x4
    1997 flat bed toy
    Have not heard anything thing good about v6 from anyone around here
  5. Mar 9, 2019 at 7:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    What v6? The 5vzfe is plenty capable and reliable(tacoma v6). The 3vz isnt that great(which is for pretacomas)
  6. Mar 9, 2019 at 7:30 PM
    Bear4x4
    1997 flat bed toy
    It’s a 1990 model he said it’s a Ivan Stewart edition I have not heard of it
  7. Mar 9, 2019 at 7:32 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    1990 isnt a tacoma
    Ivan stewart is a old off road racer for toyota, idk if he has his own model or if its a deal thing
  8. Mar 9, 2019 at 7:34 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    But if you can get your hands on a 5vzfe to replace the 3vz it will be a simple swap. Engine mounts should line up. Just need a ecu and either an adaptor for the tranny or the newer tranny
  9. Mar 9, 2019 at 7:37 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Go 5vz, if you cant, get the 22re. 22r is carborated, RE is EFI. Yotatech.com is a better site for toyota pickups than this one. Id check there for info.
    DashMaple and TacomaJunkie8691 like this.
  10. Mar 9, 2019 at 8:16 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    1990 would have a 3.0 v6 which had a huge head gasket issue. It was heavy with no power and was backed by a chain drive tcase. Nothing wrong with the tcase but if you swap in a 22r you can also use the gear driven tcase they used, but a 2nd tcase and adaptor and run dual cases for super low gearing to crawl. So I can see why someone would swap if they are replacing the 3.slow
  11. Mar 9, 2019 at 8:21 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Another vote for the 3.4. :thumbsup:
  12. Mar 10, 2019 at 1:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Op from you asking I think this is far more work then what you want to get involved in.
    22R series replacing a 3.0 frame side of the engine mounts need to be replaced find the new mounts cut the old ones off weld the new ones on
    Engine and Engine Harness with the ECU then merging the new ecu to the cab harness
    Meaning You really Should have the EWD`s of the truck and the one for the year of vehicle the engine came from .
    No matter which swap you go of a different engine with you always have the merging of the wire harnesses
    Then there is always those things that while not major do arise fuel lines exhaust connections all those annoying little things
    There is nothing wrong with the 22R or 22RE for what it is A little over 100 horse power in a heavy vehicle .
    Once I did my first 3.4 swap though I kinda stopped driving them to be truthful unless I really had to
  13. Mar 10, 2019 at 4:56 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Lets make it easy.
    If you have to ask this question, you cannot do it.
    Not trying to be rude, just a huge undertaking, for little reward, for a lot of money better spent elsewhere.
    Wulf likes this.
