can vf tuner calibrate the speedometer?
Discussion in 'Performance and Tuning' started by soggyBottom, Jul 6, 2023.
  1. Jul 6, 2023 at 9:01 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    When you set the tire radius and/or gear ratio in vf tuner, is this strictly for shifting or does it also change the speedometer calibration? If not, can vf tuner recalibrate the speedometer?
  2. Jul 6, 2023 at 9:25 AM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Shifting only. Speedometer is driven by wheel sensors and fed into the ABS computer, which VF doesn’t access. Only way to correct speedometer is with Hypertech or Rough Country recalibration units.
    drizzoh and soggyBottom[OP] like this.
  3. Jul 6, 2023 at 9:53 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    This is what a lot of us have used for the speedo recalibration: https://www.amazon.com/Rough-Country-Speedometer-Calibrator-90043/dp/B07KLYVF1Y
    Let me know if you go with it and need any help setting it up. I've done a few.
  4. Jul 6, 2023 at 10:02 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Those maps also affect the distance to empty value. :thumbsup:
    BortisYeltzen[QUOTED] likes this.
  5. Jul 6, 2023 at 10:04 AM
    soggyBottom
    are you saying distance to empty is based on vf tune or hypertech etc.?
  6. Jul 6, 2023 at 10:06 AM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Based on values that are editable within vF Tuner. Those "constants" are used in the calculation for determining distance to empty.
  7. Aug 24, 2023 at 10:36 AM
    tacomadome
    tacomadome Well-Known Member
    But if you were to do the Hypertech, you would not want to also compensate with vfTuner right?
  8. Aug 24, 2023 at 10:56 AM
    wahoobie
    chris
    Suffolk, VA
    They do not communicate with each other. Just think of them as independent systems in that you want then both to be accurate as possible (i.e the ECU to know the correct wheel spin AND the correct display on the speedo) then you can get a Hypertech AND a proper ECU/TCU tune.
  9. Aug 24, 2023 at 12:06 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Speedometer info comes from the skid control ECU, and the Hypertech compensates for that. The tune is stored on the ECU and the distance to empty takes multiple inputs from there, but it also takes the speed signal from the skid control ECU. So, technically, @wahoobie is correct; it will be more accurate if you have both (if necessary of course).
    wahoobie likes this.
  10. Aug 24, 2023 at 1:59 PM
    wahoobie
    chris
    Suffolk, VA
    I wish we had a way to provide it in the tune or with a utility process.
    ktbell444[QUOTED] likes this.
