Can we improve throttle response like this?
Discussion in 'General Automotive' started by 08pretaco, May 28, 2010.
  1. May 28, 2010 at 7:52 PM
    08pretaco
    08pretaco [OP] Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    So my Gf has a WK Jeep and I joined a Jeep forum. They have this "mod" that they do that improves or decreases throttle response.
    What you do is:
    1. Find an unused section of road with a good spot to pull-off/turn-around.
    2. Pull off of the road and shut your car off.
    3. Turn your key to the "On" position (but don't start the car), and wait for the 'idiot' lights to go out.
    4. Press down on the accelerator, and let it back up.
    5. Turn your car off.
    6. Re-start your car and cruise up and down the road testing your throttle responsiveness.
    Depending on how fast/slow you do the 4th step, your throttle will either become more or less sensitive/responsive.
    Repeat steps #1 through #5 as needed until you're satisfied that your throttle response is as good as it's going to get.
    Is this something we can do on our trucks? I have a manual 4 banger and stupidly tried it and it does nothing for my truck but maybe for an auto trans it might have a better effect? :confused:
  2. May 28, 2010 at 7:54 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    I would sincerely hope we can't alter pedal sensitivity by mashing the thing with the electrical systems fired up. If what you say is true, I'm kind of concerned, though not terribly surprised you can do so in a ChryCo.
  3. May 28, 2010 at 7:57 PM
    08pretaco
    Oliver
    az
    It was pretty amazing that the procedure "works" (butt dyno and feeling)...though if you go drive slowly after doing it it goes back to a slow throttle response but then can be altered again
  4. May 28, 2010 at 8:05 PM
    08pretaco
    Oliver
    az
    ^ thanks for the post. i had no idea that was available but ya the price is a little steep :eek:
  5. May 28, 2010 at 8:17 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    What year is the WK?
  6. May 28, 2010 at 8:26 PM
    08pretaco
    Oliver
    az
  7. May 28, 2010 at 8:46 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Hmm, wonder if that would work on the wife's 01.
  8. May 28, 2010 at 9:40 PM
    08pretaco
    Oliver
    az
    idk go ahead try it and whule your at it try it on the tacoma!
  9. May 28, 2010 at 10:05 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    My Taco has balls enough. :D
  10. May 28, 2010 at 10:13 PM
    08pretaco
    Oliver
    az
    its amazing how much drivetrain loss the jeeps have. my gf and myself have gone to a track and been supervised and completely legal and done a quick 0-60. her 3.7L awd fell very short of my 2.7L with 265/75/16's and 4.10 gears.
  11. May 28, 2010 at 10:16 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    The 3.7 is a fucking piece. The 4.0L that dodge puts into their Nitro R/T and SXT is far superiour. Something like 260 HP and Torque.
    That and the Jeep is probably heavier.
    Oh, and new jeeps suck balls.
    Question though, is the response more or less sensitive if you do the pedal fast or slow?
  12. May 28, 2010 at 10:35 PM
    08pretaco
    Oliver
    az
    the faster you do the pedal the quicker the response is
  13. May 28, 2010 at 10:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No. It wont. Only works on the throttle by wire jeeps. Doesnt work on the Tacomas either.....FWIW, the ECU resets after a few mins of driving.
  14. May 29, 2010 at 9:29 AM
    08pretaco
    Oliver
    az
    ^ there you go worthless haha thanks chris.
  15. May 29, 2010 at 9:36 AM
    jandrews
    New ChryCo products (last 5 years or so especially) have some of the worst designs in automobile history, all around.
    I have a co-worker with a 2007 Nitro that she takes EXCELLENT care of...proper maintenance and everything...the interior of the thing is starting to fall apart already. There are interior trim pieces coming loose, busted switches...it's sad. Hopefully the vital mechanical bits will hold together longer, but who knows.
  16. May 29, 2010 at 7:39 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Hmm, have to see. I have a coworker with a 2010 or 2009 (I can't remember). Strong engine, interior seems solid. Interesting to keep an eye on it. She also has the SXT though if that makes a difference.
