Can we sticky the 2nd gen hard start reasons?
Discussion in 'Site Suggestions' started by Bishop2Queens6, Jan 21, 2012.
  1. Jan 21, 2012 at 8:23 AM
    Bishop2Queens6
    Bishop2Queens6 [OP] Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    We have seen in the second gen section multiple threads on the second gen hard start, long crank, when new or when I disconnected my baterry for so and so reason. In the past 2 weeks alone I counted 3 threads on people seeking answers to the hard start.
    Can we sticky why 2nd gen's have a hard long crank when new or after you disconnect the battery? The following reason was explained to me by a good friend who is a certified Toyota tech and is a regular tuner on my.is
    "Believe it or not, this is a fairly common issue to new vehicles or even when you pull your battery cable to reset the computer.
    What happens is that the factor default setting for the A/F ratio runs rich causing hard starts, that is where you are getting your long cranks from. The vehicle computer needs to learn the ideal A/F ratio for you area, driving style and habits which does take time, a few thousand miles.
    When ever I go from my flat land by the ocean to my local mountains which exceed 6000 ft elevation, I get hard starts when I'm in the hills. The computer is used to more air then it normally gets. It's using a circumstancially rich A/F ratio.
    Hopefully this clarifies things."
