Can weather cause P2757 code in a 2011?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueGrassBammer, Feb 16, 2021.
  1. Feb 16, 2021 at 7:53 AM
    BlueGrassBammer
    BlueGrassBammer [OP] Member
    2011 Black Tacoma DCSB
    2011 DCSB Auto. Last week driving through snow truck threw a P2757. No symptoms. Smooth shifting. I cleared the code and did a drain a fill on the AT fluid. Drove several hundred miles with no issue. This morning I leave for work in the ice storm. I throw a code halfway here. No symptoms but I'm pretty sure its the same code. Can this be temperature related?
  2. Feb 16, 2021 at 8:47 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    It’s just a coincidence.
  3. Feb 16, 2021 at 9:07 AM
    BlueGrassBammer
    Everything I can find on Tacomaworld relates to shudder or some other transmission symptom. I'm guessing I'll have to take this to a mechanic.
  4. Feb 16, 2021 at 9:22 AM
    spitdog
    When you did a D&F did you put it in temp check mode and check if it was at the proper level.
  5. Feb 16, 2021 at 9:25 AM
    BlueGrassBammer
    yeah but I was a little iffy on the definition of trickle. I got 2.5 quarts out, put 3 in, got it to temp and half a quart came gushing out. It got to what I consider a trickle, like a bad leaky faucet and I closed it.
  6. Feb 16, 2021 at 9:26 AM
    spitdog
    Your probably good. Mine holds a little over 3 qts.
  7. Feb 16, 2021 at 10:29 AM
    BlueGrassBammer
    Is there a next step I can take trying to diagnose this? I can't find a leak anywhere. The transmission fluid looked awful and is probably 170k old.
  8. Feb 16, 2021 at 10:44 AM
    spitdog
    You should really take it to a pro. Hopefully you have a dedicated transmission shop near you. With that many miles, the pan should be dropped, solenoids and valve body looked at and tested, screen cleaned / replaced, new fluid ect. The ole phrase......Pay me now..or pay me later, comes to mind.
  9. Feb 16, 2021 at 12:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the Trans fluid is full and correct, the the next steps aren’t exactly something you want to jump into with out the proper knowledge of how a transmission works. And how to repair them.
    What information I have found on that code relates to the following:
    • Shift solenoid valve SLU remains open or closed
    • Valve body is blocked
    • Torque converter clutch
    • Automatic transmission (clutch, brake or gear, etc.)
    • Line pressure is too low
    I myself don’t know anything past checking the fluid level.
    So, I’d need to have a professional look at it.
  10. Feb 22, 2021 at 8:12 AM
    BlueGrassBammer
    So I dropped my truck off at the dealership. Told them about the code and that I had no symptoms. 140$ later they call and tell me that I most likely have a bad Shift Solenoid. Naturally I asked if they could replace it. They told me they are not allowed to do anything but replace the transmission which they quoted me a price on. I asked how they diagnosed it if they aren't allowed to open a transmission they said they used the code reader. I'm completely shattered. I guess I'm gonna be replacing a solenoid on my own. Any clue how difficult this is?
  11. Feb 22, 2021 at 8:26 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Seek out a shop that specializes in TRANSMISSIONS ONLY.
    Get the diagnosis, quote, then decide.
    An automatic transmission is one of the most complex pieces of kit on the truck.
    IMHO, you likely do have a stuck valve or bad solenoid, especially at 170 kmiles and poor fluid condition.
  12. Feb 22, 2021 at 8:30 AM
    spitdog
    See post 8, you got the stealership treatment. Take it to a dedicated transmission shop. $140 down the drain.
