Can you add OEM TRD bed outlets.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dessertsand05, Nov 6, 2010.
  1. Nov 6, 2010 at 6:56 PM
    dessertsand05
    dessertsand05 [OP] Well-Known Member
    Boston
    05 Tacoma DC SR5 4x4
    Working on it
    I have an 05 DC 4x4 SR5 nonTRD. The trd bed outlets looks nice for camping and such, doubt I would use them for much else, but was consider getting an inverter and doing a custom mod.
    But I noticed in a thread about adding a fog light switch that some of the connectors are behind the blank plug. If the wiring is there, would it be possible to get the parts and install the switch, inverter, and bed outlet?
    Seems a better option, juts not sure what parts are required or how much would be involved......is it it possible?
  2. Nov 6, 2010 at 7:03 PM
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
  3. Nov 6, 2010 at 7:05 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    IIRC some folks looked at doing them and the little cubbies and stuff were insane expensive (like 200+ bucks for the plug/plastic) and the size of the inverter is limited. You are probably better off wiring an inverter directly into the bed or something, as far as $$ is concerned.
  4. Nov 7, 2010 at 2:27 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    I'd fab an outlet and install an inverter under the hood. Minding they are not water or heat friendly. There's lots of room on the fenders... run an extension cord out back and mount it somewhere. Switch it from the ignition or with a relay direct to battery. only 400watts with factory.. 2000 would be an easy walmart trip.
  5. Nov 7, 2010 at 3:03 AM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    I'm trying to figure out a use for it. Guess I should try it before the 3/36 goes tits up.
  6. Nov 7, 2010 at 4:20 AM
    dessertsand05
    Boston
    Working on it
    But would you be able to get it look to stock? The thing is if the wire is there. There are plenty of wrecking yards with tacomas in them, anyone have the part list or an idea of whar I would need, if the wiring is already rigged in the truck?
  7. Nov 7, 2010 at 9:56 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I never use that thing. But "IF" I were in your position? I would install a better inverter under the console where the stock one is located, and just put the outlets on the back of the console.
  8. Nov 8, 2010 at 12:22 AM
    island808
    Jedediah
    hawaii
    Its under the console? I didn't see it. Though I did trace the wires back to under the seat.
    I was thinking of doing that exact thing however for interior space and it would be way too tight. Not only would I have to remove the cover from the smallest (400 watt) inverter I could find but it would probably overheat.
