Can you apply fluid film on a rainy day?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fgeorge097, Aug 17, 2018.
  1. Aug 17, 2018 at 8:26 AM
    fgeorge097
    fgeorge097 [OP] Well-Known Member
    Northeast
    2018 OR AT
    I was going to take my truck in to get fluid filmed this weekend, but it is supposed to be rainy all week. i leave it parked outside. Is the rain going to spoil the fluid film?
    Not sure if I need to get it applied on a sunny week, so it has time to dry/set in.
    GQ7227 likes this.
  2. Aug 17, 2018 at 8:33 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Sunny days are recommended so that the fluid film can warm up and seep into all the cracks and crevices. The rain likely won't wash it off but I would probably wait for peace of mind.
  3. Aug 17, 2018 at 8:41 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Curious if there are places around that FF for you? I've always just done it myself and to get back to your question, I would wait for a sunny stretch to do it outside and let the heat do its job. Also want to make sure the frame is dry and clean before applying it
  4. Aug 17, 2018 at 9:13 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Is snow season starting soon where you are?
    If not, are you getting some pre- season discount?
    Personally, I would wait to apply it sooner to the time road salt will be used.
    If you have a concern about application during rain, I would call the company directly and speak with someone there- 888-387-3522
    Fluid film is good stuff- I spray it on myself on a twice per year schedule- fall and spring.
    I would not apply it if it was raining or forecasted to rain, fwiw.
  5. Aug 17, 2018 at 9:22 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    "Can you apply fluid film on a rainy day?"
    This sounds like a chorus verse for a country jam. some deep shit going on here.
  6. Aug 17, 2018 at 10:07 AM
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    Yes you can apply fluid film on a rainy day.
    FF doesn’t need to “cure” or “set”.... it stays wet... and seeing as it’s designed to keep water off the chassis.....rain isn’t going to effect it any.
    As for getting hot and weeping into the nooks and crannies..... it’s going to do that any time it gets hot after it’s been applied.... it doesn’t need to be the same day
    Fluid film away and don’t worry about it
  7. Feb 2, 2020 at 7:31 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i will have to beg to differ there, had 2 failures in key splash areas in rear wheel wells on my old truck
    i may have applied it out of season IDK why is just washed clean off rolling down a wet splashy road
    but its disappearance induced some major flash rust under there that i was trying to clean and proper coat with HD stuff
    had to temp primer the area and now is coated with some real NASTY corrosionX that I will keep an eye on for durability until late spring when temps are better
    i may have pics as proof but might have one in the set missing was so fed up with it when it was 0 degrees out and my frame was all crusty orange looked it sickened me :mad:
  8. Feb 2, 2020 at 7:57 PM
    DR TACO
    DR TACO Well-Known Member
    Denny
    Fort Mohave
    2019 Tacoma Off Road 4x4 Double Cab
    Pro grille, POD lights, SEMA wheels.
    As long as she says yes.
    Speedbird likes this.
