Can you buy the 4.30 gears from Toyota?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maxrider, Jan 15, 2017.
  1. Jan 18, 2017 at 8:54 AM
    #61
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Yes, that's literally the point people regear in 3rd gens. There is no low-end torque and some people don't want to floor it all the time to be in the power-range.
  2. Jan 18, 2017 at 9:01 AM
    #62
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    IDK. I've never driven one. If that's what he's doing it for then it should help as long as he understands it's not going to be like stock
  3. Jan 18, 2017 at 9:01 AM
    #63
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    True but not a lot. I think the reported RPM change at 75 or 85mph is about 250 rpms. Thats negligible and not worth arguing.
    People with larger tires have also reported a gain in mpg...
  4. Jan 18, 2017 at 9:01 AM
    #64
    c4lvinnn
    JoeCOVA likes this.
  5. Jan 18, 2017 at 9:10 AM
    #65
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Your idea makes 100% perfect sense just do it.
  6. Jan 18, 2017 at 9:34 AM
    #66
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    I have 4.30 gears stock on my SR 2.7 4 Cylinder. I just installed 265/75 tires and didn't really notice too much of a difference of power loss.
    OP please relax..
  7. Jan 18, 2017 at 9:38 AM
    #67
    JoeCOVA
    Joe
    Colorado Springs
    May be negligible but you have a different final drive ratio.
  8. Jan 18, 2017 at 9:42 AM
    #68
    BeaverNation
    BeaverNation Well-Known Member
    People shouldn't post in gear threads unless they understand the double overdrive. This is not like any other toyota pickup or 4Runner. I maintain that I'd prefer 4.88's on a stock tire sized 16+.
  9. Jan 18, 2017 at 9:50 AM
    #69
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    OP:
    In your current setup you're probably turning around 1800 RPM's at 75mph.
    265/75R16 @ 75mph in 6th
    3.90's = 1800RPM
    4.30's = 1985RPM
    4.88's = 2250RPM
    285/75R16 @ 75mph in 6th
    3.90 = 1736RPM
    4.30 = 1914RPM
    4.88 = 2172RPM
    Now, this is based on your 6th gear ratio of .58; your 5th gear ratio is .69. 265/75R16's at 75mph in 5th gear works out to 2142RPM, which is nearly identical to the 2172 that you'll have if you switch to 4.88's and 285's.
    My advice to you, OP, before you bother spending time, money, and effort on regearing your truck and buying bigger tires would be to go out and drive your truck with it locked into 5th, and see if the extra 400 RPM's or so annoy you. If they do, DON'T regear. If they don't bother you, go for it.
    Though as a disclaimer I still think it's a waste of afore-mentioned time, money, & effort when all you need to do to fix your perceived problem is just push a button and lock out 6th gear when you think it's shifting too much. This solution lets you have the extra power and fewer shifts when you want it, while keeping the higher MPG's when you're just cruising along and don't need the extra oomph.
    securekey, JoeCOVA and c4lvinnn like this.
  10. Jan 18, 2017 at 9:50 AM
    #70
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    Yes but I have a 4 banger, has no power whatsoever. It drives just fine with 265s and the ECT button helps like it should on the highway.
    I also have p rated 265 tires, LT/E are overkill for this light weight underpowered truck.
    JoeCOVA[QUOTED] likes this.
  11. Jan 18, 2017 at 10:26 AM
    #71
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I think that's what he's going for. He doesn't like the way it is stock and so wants to change the gearing. There are plenty of reasons to change gearing besides changing the tire size on a vehicle.
    Jeff
  12. Jan 18, 2017 at 12:09 PM
    #72
    maxrider
    maxrider [OP] Well-Known Member
    2017 TRD OFF ROAD
    Exactly, I feel the truck is geared to high from the factory. That's the real issues with gen3 tacomas. Toyota was so focused on getting better gas mileage they forgot about how shitty it made the truck feel.
    JoeCOVA likes this.
  13. Jan 18, 2017 at 12:12 PM
    #73
    maxrider
    2017 TRD OFF ROAD
    That would be all fine if it would stay here n 6th for more than 30 seconds or so. The slitest up grade or wind and it's down shifting constantly. And when a truck has to down shift twice to go up a hill something isn't right.
    JoeCOVA likes this.
  14. Jan 18, 2017 at 12:44 PM
    #74
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    I mean I agree with the gearing being to high with the 6 speed transmission. 5th and 6th are actually overdrive. Mine will pop out of 6th and downshift to 4th or 5th on the smallest inclines doing 70mph. I actually just let myself slow down to 60 and then let the decline pick the truck back up to 70 lol. This damn tranny.
  15. Jan 18, 2017 at 12:44 PM
    #75
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    This Tacoma is completely different in that it has a double overdrive. The charts reflect 1 to 1 because it's a constant and easy to calculate. They say gear three because in the old days all automatic transmissions were three speeds and position three would be 1 to 1 . The Tacoma double overdrive , gear four is 1 to 1.
  16. Jan 18, 2017 at 12:54 PM
    #76
    Noelie84
    Noel
    Wales, Maine
    My truck has a double overdrive as well, but the OD ratios are .86 & .69 hooked up to 3.55's in back.
    I don't actually have a 1:1 gear, though, as 4th is 1.14:1.
    But, it also doesn't shift back and forth on hills, which is nice.
  17. Jan 18, 2017 at 1:38 PM
    #77
    Hiluxski
    Ventura California
    All true but what does if have to do with a Tacoma ?
  18. Jan 18, 2017 at 1:39 PM
    #78
    Noelie84
    Noel
    Wales, Maine
    Mostly that the Tacoma isn't 'completely different' because it has a double overdrive. Most trucks have them now. But some of them do have them mapped out better. Part of why I ended up in an F150 is because I wasn't impressed with the Tacoma's geabox. :notsure:
  19. Jan 18, 2017 at 3:14 PM
    #79
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I think it's going to be a bigger change in rpms, I did a smaller jump from 4.30 to 4.88 and I gained about 200-250 rpms, I would expect 350-450 gain in rpm at 70-75.
  20. Jan 18, 2017 at 4:23 PM
    #80
    Hiluxski
    Ventura California
    Im saying "completely different" for the new Toyota Tacoma Vs old Toyota Tacoma not comparing it to other brands. You're right double overdrive is not that rare as a matter of fact the Lexus GX 460 has had it since 2010.
