Can you buy the 4.30 gears from Toyota?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maxrider, Jan 15, 2017.
  1. Jan 18, 2017 at 4:33 PM
    #81
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Lexus is Toyota ....
  2. Jan 18, 2017 at 4:35 PM
    #82
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Wow
    JoeCOVA[QUOTED] likes this.
  3. Jan 18, 2017 at 4:37 PM
    #83
    JoeCOVA
    Joe
    Colorado Springs
    Thank you, im here all week.
  4. Jan 18, 2017 at 6:09 PM
    #84
    maxrider
    maxrider [OP] Well-Known Member
    2017 TRD OFF ROAD
    And that would be perfect, put it around 2500 rpm at 75mph. Give the truck a little balls
  5. Jan 18, 2017 at 8:27 PM
    #85
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    A lot of people tend to look at just the final drive, or just the transmission gearing, or talk about changing the tire size, etc. Something that not enough people do is look at the entire picture, and that is to take into account, for each gear, the transmission gearing, the final drive, and the tire size and combine them all into a single number that you can now compare between different trim levels, vehicles even.
    Here are the overall ratios for the 2016-17 Tacoma V6 A/T and M/T. Notice that 2nd, 3rd and 4th gears are almost identical, while 1st, 5th and 6th are where the differences all lie, with the 6MT shorter than the 6AT.
    Now take a look at the 6AT with 4.88's and stock tires:
    This is what the OP was asking about:
    Finally, OP's tire size suggestion with 4.88's:
    No insanity in really any of these options, I don't think. Even without changing tire size, 4.88's in the 6AT still have a taller 6th gear than the 6MT stock.
    Jeff
    IB87, Durango95, speedtre and 2 others like this.
  6. Jan 18, 2017 at 8:34 PM
    #86
    maxrider
    2017 TRD OFF ROAD
    That's a good explanation thanks. The 6MT must get really shitty gas mileage from the looks of the gearing. But I bet it's a got plenty of power
  7. Jan 18, 2017 at 10:59 PM
    #87
    Chris.taco.2016
    Chris.taco.2016 Well-Known Member
    2016 Tacoma trd sport mgm dclb
    Can't we get Yukon 4.88 gears for the sport since I believe it has the same front and rear diffs from the 2nd gen? Only the off-road changed the rear end to the 8.75. Someone wanna chime in?
  8. Jan 19, 2017 at 12:08 AM
    #88
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I
    It does have plenty of power :) even with 285s
  9. Jan 19, 2017 at 5:06 AM
    #89
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    AH, I see. My bad; I misinterpreted your wording.
  10. Jan 19, 2017 at 5:16 AM
    #90
    Noelie84
    Noel
    Wales, Maine
    I'm not sure that regearing to 4.88's and putting 285's on will prevent that; You're still going to be pushing the truck along in 6th going down the highway. The revs will be a little bit higher, but you'll be pushing larger, heavier tires with more rolling resistance, which means that when you hit a hill the transmission is still going to downshift into a more efficient gear. I'm just not certain if the extra rev count will be enough to keep it from kicking down one. It would be too bad if you put that effort in and it didn't resolve your issue.
    Of course, a mild lift and 285's will look badass, so there's that to consider too. :notsure:
  11. Jan 19, 2017 at 5:45 AM
    #91
    Nimrodical
    Nimrodical Active Member
    2002 Tacoma double cab. 2002 Porsche 911. 2012 Subaru Outback
  12. Jan 19, 2017 at 6:47 AM
    #92
    JoeCOVA
    Joe
    Colorado Springs
    Thanks for posting this Jeff. This is awesome. Everyone looking to regear should see this.
  13. Feb 15, 2017 at 3:14 PM
    #93
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    Jeff,
    The above part numbers are for the 4.30 ratio?
    Also you mention a Toyota 4.56, is this available in the 8.75" rear dif size?
  14. Feb 16, 2017 at 10:59 AM
    #94
    Jeff Lange
    Calgary, Canada
    Yes, those are 4.30:1 ratio gear sets.
    I believe the 4.56 is available in the 8.8 size as well, but I would need to check into it.
    Jeff
  15. Feb 16, 2017 at 11:39 AM
    #95
    Hautian
    Hautian Well-Known Member
    Upper Peninsula, Michigan
    2016 Silver TRD OR - sold / 2022 4Runner
    If you get a chance to check that would be awesome. 4.56 seems about perfect for 255/80r17 tires.
  16. Feb 16, 2017 at 12:31 PM
    #96
    Hiluxski
    Ventura California
    I don't think you're going to find a OEM Toyota gear for the 8.75" in a 4.56 ratio because it is not in anything. What vehicle would have a 456 ratio with that rear axle?
  17. Feb 16, 2017 at 7:27 PM
    #97
    Jeff Lange
    Calgary, Canada
    4.56:1 Front: 41201-09C90 or 41201-79495
    4.56:1 Rear 8.8: 41201-09C10
    Hilux and Fortuner.
    Jeff
  18. Feb 16, 2017 at 8:21 PM
    #98
    duckytw
    duckytw Well-Known Member
    Exactly the reason why the of-cited "automatics have gotten so good these days they beat manuals for mpgs" is usually so, so, so wrong. I remember the old days when you could factory order cars one option at a time and pretty much any gears you wanted. Course they only had like 3 gears to change out anyways.
  19. Sep 27, 2017 at 10:11 PM
    #99
    NerdTaco
    NerdTaco Well-Known Member
    Is that for the E-locking version? Or do they not make that?
  20. Sep 28, 2017 at 9:29 AM
    #100
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    Yes, the 8.8 is what is used with the lockers, as well as every manual third gen
