Can you fit 35s on stock sport 17s?
Discussion in 'Wheels & Tires' started by 09 tacomaa, May 12, 2011.
  1. May 12, 2011 at 7:16 PM
    09 tacomaa
    09 tacomaa [OP] Well-Known Member
    Cole
    Gtown. South Carolina
    09 Tacoma TRD Sport 4x4
    Westin Ultimate chrome bull bar, 6" off road light(2), husky toolbox, cobra cb and 102" whip.
    also can you stuff em on with a 3" with minor trimming?
  2. May 12, 2011 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not with minor trimming.
  3. May 12, 2011 at 7:19 PM
    09 tacomaa
    Cole
    but they would fit on the stock rims? and some wheel spacers?
  4. May 12, 2011 at 7:21 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Doubtful that they will fit on stock rims. You'll want a 8-9 inch wide rim for something like a 35-12.5-17
  5. May 12, 2011 at 7:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You are correct.
  6. May 12, 2011 at 7:23 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    Hmm. May need a wider wheel...at least 8" but :notsure:
  7. May 12, 2011 at 7:26 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    35's on a 3" lift? :confused:
  8. May 12, 2011 at 7:26 PM
    malander
    max
    01 limited trd 4x4
    Well shit a 44" tire that's 10" wide will fit on a oem wheel. That's not much of a question.
  9. May 12, 2011 at 7:26 PM
    malander
    max
    01 limited trd 4x4
    Its been done before. Lots a cuttin
  10. May 12, 2011 at 7:29 PM
    Tberry5000
    Tberry5000 Well-Known Member
    Travis
    Florida
    super white tacoma
    one day....
    honestly dude dont try it, i have a 6inch with 35's and i still rub like a B*#@h!
  11. May 12, 2011 at 7:33 PM
    09 tacomaa
    Cole
    ok thanks guys
  12. May 12, 2011 at 7:33 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    They will fit on your wheels, no problem there... Fitting the 35s in the wheel well will be much harder to do and will involve intesive cutting, pounding and other manipulations of your wheel wells. GL
  13. May 12, 2011 at 7:39 PM
    Tberry5000
    Travis
    Florida
    super white tacoma
    one day....
    he basically said it all :) and personally i would go with 33's on a stock truck. still you will have rubbing but it wont be near the same as it would with 35's. you will have to do a little trimming.
  14. May 12, 2011 at 9:33 PM
    Blacktacoma23
    2011 Mall Crawler
    Lol :rofl:
  15. May 13, 2011 at 3:03 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    I'm looking into a six inch and I'm probably gonna go with 33 inch rubber. That's plenty big for me.
  16. May 13, 2011 at 3:15 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    35 x 12.5 or even a 315-70R17 Is really pushing it on a 17" diameter 7.5" wide rim. Even with 16"s you're supposed to have at least an 8" wide rim. And as others have said a 35" on a 3" lift is doable with lots of triming including cab mount chop.
  17. May 13, 2011 at 3:17 PM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Just a question why would you want to put 35's on stock wheels?
  18. May 13, 2011 at 10:07 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Tire manufacturers for 35s or 315s suggest an 8" wide wheel. Some shops will install them on a 7" wheel but you may have weird wear as it causes the tires to balloon. It's really worth getting the proper wheel width.
    You can make 35s fit with a 3" lift but it will require a lot of cutting and modification. Check my build thread if you're interested. I had to chop my cab mounts a bunch, pounded the fuck out of the firewall and pinch weld with a sledge and I'm still playing with my alignment and a couple other things trying to eliminate any rubbing. I also cut the fenders and had a body shop cut the flares. You may also choose to re-gear.
    There are a few of us running 35s and I wasn't the first. Check around.
