Can you fix taco lean w/ coilovers ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Razorecko, Jul 16, 2009.
  1. Jul 16, 2009 at 6:13 PM
    Razorecko
    Razorecko [OP] Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    I just had my toytec ultimate kit installed and through this I found the infamous taco lean on the drivers side. Is it better to ....
    1. Leave the lean alone
    2. Adjust the coilver to compensate for the / .5in sag
    3. Put a spacer ontop ( toyec 1/4" spacer )
  2. Jul 16, 2009 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Adjust the CO 1/4"
  3. Jul 16, 2009 at 6:29 PM
    Razorecko
    ^ thanks ! wasn't sure what was the best option. I'm guessing i'd need another alignment or would that 1/4" adjustment be within spec
  4. Jul 16, 2009 at 6:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It should be fine, but I would throw it on a rack just to make sure.
  5. Jul 16, 2009 at 6:35 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2...had a buddy w/ the same problem
  6. Jul 16, 2009 at 6:37 PM
    Razorecko
    ^ so adjust the co 1/4" for every 1/2" you want to drop right ? I never thought that 1/2" would be so visible with a lift -from the back it looks like its getting a flat tire almost
  7. Jul 16, 2009 at 6:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Or to lift....
  8. Jul 16, 2009 at 6:54 PM
    Razorecko
    off topic but i have 285/75/16 duratrac's that have a max psi rating of 80 / any suggestion as what psi I should even start testing them with ?
  9. Jul 16, 2009 at 7:03 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
  10. Jul 16, 2009 at 7:05 PM
    Razorecko
    Thanks- 60psi from the dealer felt like a self-vasectomy
  11. Jul 16, 2009 at 7:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as the propper tire pressure varies from tire to tire, vehicle to vehicle, theb est way to determin propper pressure for the tires is by useing the chaulk method.
