Can you get good mileage with 6 cylinders?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vgerder, Oct 9, 2013.
  1. Oct 9, 2013 at 3:08 PM
    vgerder
    vgerder [OP] New Member
    David
    Cornersville, TN
    01 tucoma
    none
    I only seem to get about 18 mpg at best. It is just a stock 4wd extended cab truck.
  2. Oct 9, 2013 at 3:13 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    Is 18mpg bad? I only get 18-20mpg with my 4 cylinder. Is 18mpg on the highway or in the city? Do you drive on flat ground or hills?
  3. Oct 9, 2013 at 3:15 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I've got a 95.5, 4wd, Extended Cab, 3.4, manual; all stock
    I run 31 10.5 15's; got Redline oil/fluid in everything
    Use Chevron 92
    Get around 22 if I take the freeway at 75mph
    Get around 24 if I keep it under 55mph
    Edit: 70mph is generally my freeway speed
  4. Oct 9, 2013 at 3:32 PM
    BackwoodsTaco
    BackwoodsTaco Well-Known Member
    Paul
    Stokes, NC (Eastern NC)
    Radiant Red 01 DC, 4X4, SR5, Supercharged
    TRD Supercharger, URD 7th injector kit, TRS RetroFit, Deck Plate Mod, No Chime Mod, Fog Light Mod, CB/ashtray Mod, 2.5" Spacer Lift, 1.25" Lift Shackles, 4 Tab Light Bar From Eddie209
    I get 18-20 depending on how I'm driving with a 01 DCSB with 265/75/16 Destination M/Ts. kinda shocking ain't it lol
  5. Oct 9, 2013 at 3:35 PM
    JIB83
    JIB83 Well-Known Member
    Perris, CA
    2017 Tacoma double cab 4x4
    haha I am getting about 16-18 on my 02 DCSB 4x4. Running 265/70R17 BFG A/T
  6. Oct 9, 2013 at 3:38 PM
    Musselman32
    Musselman32 Member
    corey
    cali 714 anaheim
    13 toyota tacoma
    none yet
    throw the fucker in neutral :cheers:
  7. Oct 9, 2013 at 3:39 PM
    sfcyclist
    sfcyclist Well-Known Member
    SF
    06' Super White DCSB PreRunner TRD
    Yakima Truck Bed Rack, Derped front bumper Spidertrax 1.25 all around Husky Custom Front Mud Guards. Yakima Bed Rack Trac Rac cross bars with Thule cargo box Planned; Parking light as blinkers
  8. Oct 9, 2013 at 3:41 PM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    I get 17 pretty much constantly. 3.4 5 speed. AC
  9. Oct 9, 2013 at 3:45 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    3.4l in auto double cab. Mid travel. 33 bfg at in d. I get 17. Keep it under 65 on the freeway.
  10. Oct 9, 2013 at 6:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    im getting 20.2 with my double cab 4x4 V6 auto.
    keep your foot out of it.
    by contrast..Frankenstein gets like 10mpg.
  11. Oct 9, 2013 at 6:07 PM
    Madjik_Man
    Colorado Front Range
    My mileage is plummeting now that my typical commute is one mile when the engine doesn't even get warm
  12. Oct 9, 2013 at 6:27 PM
    cruiserkev
    cruiserkev Well-Known Member
    Kevin
    Lakewood, WA
    Used to get 18-20 when I ran the stock Goodyear 31" street tires. That went to about 16 mpg when I got some 31" Les Scwab mudders a few years later. Now I'm getting around 14 on 33"x 12.50 Procomps. :(
  13. Oct 9, 2013 at 7:16 PM
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    dang i am torn between 33s and 31s for my next set. duratracs on my 98 tacoma 5 speed
  14. Oct 10, 2013 at 6:41 AM
    Minnetacoma
    Minnetacoma Well-Known Member
    Elliott
    Minnesota
    96 tacoma sr5 with oe sunroof
    3.5 fabtech suspension lift with dirt logic shocks, Wheelers Alcon 8 pack rear leafs with extended brake line All pro rock sliders Cbi DIY front bumper with m8000 winch Cbi bushmaster 1.0 non swing arm 33x10.5 BFG mud terrains Skid row front skid plate Trs headlight retro fit fxr 2.5in projectors with rbg halos Audio/electrical upgrades K2 73ah lithium battery Big 4 upgrade 300a Ohio generator alt Alpine type r 6.5 coaxials in front Alpine type s 6.5 coaxials in back Alpine double din touchscreen Digital designs z3 15” subwoofer Digital designs m4 amp Alpine ktp 445u behind the dash amp for speakers 152db
    75-80 mph gets me down around 16.5-17mpg
    65 gets me 19-20 mpg
    55 I don't even know yet lol I'm gonna have to go on a road trip that consists of no highways to figure that one out.... And I consider those great mpg cause my lifted gmc is lucky to touch 13-14 if its all down hill lol
  15. Oct 10, 2013 at 7:06 AM
    vgerder
    David
    Cornersville, TN
    01 tucoma
    none
    I live in the country so it could be a little of each. There are not a lot of areas that are flat either. From what I am reading it looks like 18mpg is not to bad. I had hoped to be able to get more. Oh well
  16. Oct 10, 2013 at 7:28 AM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Best I ever saw in my truck was 22mpg and that was driving 55mph on a flat highway with no wind. Doesn't matter if I drive like a grandpa, I still get 16-17mpg regularly. I actually believe it helps to drive like a maniac, I see better mpg numbers. Those claiming 20+mpg at 75mph are on crack. About as bad as the guys claiming their Dodge Cummins on 35" tires gets 25mpg towing 10k uphill [​IMG]
  17. Oct 10, 2013 at 8:08 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Absolutely. MPG's actually doesn’t have all that much to do with the engine.
    Think of it this way:
    An object that weighs xlbs needs y amount of energy to move from one point to another. The energy comes from the fuel but energy is lost in:
    -Internal/External friction
    -Burn efficiency
    -Drive train efficiency/Transmission gearing
    Typical engines burns fuel at a 25-30% (up to %35 with DI engines) with an additional 20-30% efficiency lost in the power train. That means of all the potential energy in gas, only ~%15-20 is actually used (% varies with engines/cars).
    This can get more complicated as most engines have different efficiencies based on the RPM’s they are running at. Variable Valve Timing helps increase efficiency over a wide RPM band and a well-tuned transmission can help keep the engine in its max efficiency power band. A CVT transmission can maintain the engines RPM’s (keep it at its max efficient RPM at the cost of performance) and adjust speed by dynamically changing the gear ratio (as seen in most hybrid cars).
    In the end, the idea that bigger engines are worse for MPG’s is kind of a misplaced concept. The only way a bigger engine adversely effects MPG’s is:
    -Heavier. More inertia to overcome
    -Typically has more internal friction
    And of course, don’t forget the Manufacture design factor: Bigger engine/transmission/drivetrain/etc… are generally designed to perform (either go fast or pull/carry heavy stuff) not sip gas.
    Now if you are just referring to the Tacoma, not really. You can lighten the truck, get smaller tires and comparable gearing, and drive like a crippled grandmother.
  18. Oct 11, 2013 at 10:37 AM
    kn38ms
    kn38ms Well-Known Member
    NW, FL
    I routinely get 400 miles per tank.
    My best was 23 on a long freeway run with AC off going 60-70mph
    100% stock 2002 V6 ext cab TRD AOD
    New Michelin street tread tires
    Mobile1 5/30
    I burn Chevron 90 octane marine gas only (100% gasoline no corn)
  19. Oct 11, 2013 at 10:48 AM
    WThomas1250
    WThomas1250 Well-Known Member
    My manual 3.4L 1998 TRD is completely stock and I average around 21. Sometimes worse, sometimes better.
    My commute is about 55 miles a day, 16 of those are interstate driving 70-85 mph. The rest of those are city and backroads.
  20. Oct 11, 2013 at 10:52 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Hypermiling FTW!! :woot:
