Can you go back to stock tune?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Backwoodsraider, Sep 25, 2018.
  1. Sep 25, 2018 at 5:12 AM
    Backwoodsraider
    Backwoodsraider [OP] Active Member
    Had the 0062 done, now truck seems worse. 2018 sr5 4wd buld date may 18.
    anyway i can revert this tune back?
  2. Sep 25, 2018 at 6:03 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Simple answer is no, once the latest tsb tune is applied, you can’t go back
  3. Sep 25, 2018 at 6:26 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Interesting. I have a '17 and the TSB was a big step forward, but I know the 18s drove a bit differently. how exactly is it worse?
  4. Sep 25, 2018 at 6:29 AM
    Puddle_Jumper
    Puddle_Jumper Well-Known Member
    Bruce County Ontario Canada
    2017' Tacoma TRD Off-road DCSB
    Bilstien 2/1 level kit with 5100’s front (top setting) and 5160’s in the rear Ecgs bushing Prinsu cab rack Bestop Cali raised ditch lights Rago fab bed stiffeners Rssw heritage wheels with 32” ko2’s Westin bed mat Pro grille and tail lights Led dome, map and licence plate lights
    Ive got a 17 and just had the update done and it drives alot better for me,but it is still in learning mode again once the update is done
  5. Sep 25, 2018 at 9:40 AM
    Backwoodsraider
    low rpm cruising, stumbles. like arpund 1k to 1300. no matter the speed. seems lack of power from a stop.
    ill add, they did the tune because i complained that around 70 it seemed like it stuttered, bad gas or air in line feeling.
    right now, also appears to be in 6th gear at 20 mph
  6. Sep 25, 2018 at 11:55 AM
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    I keep going back and forth on my truck.. Some days I really love the way it drives and others I hate it.
    I have learned that keeping it around 2500 is the sweet spot--I use S mode so I can achieve that.
    I want the 4.88 or 5.29 gears, but I am afraid how it will affect my MPG since I drive 30 miles one way for work.
  7. Sep 25, 2018 at 3:16 PM
    bshammer0
    Brandon
    Nashville, TN
    And this is the problem. It's unpredictable. Some days I smile ear to ear. Other days I can't figure out why it wants to lug and be sluggish off the line. Next day it could run marvelous with none of that. According to OVtune, there are like 1200 shift maps it cycles through constantly that change the driving characteristics, plus the throttle isn't really a throttle. Often just says... wait for load to hit a certain threshold and downshift. which is why there is a lot of activity in the OVtune threads for 1.05!
  8. Sep 25, 2018 at 3:28 PM
    75z28
    Homer
    Yep, I have thought about going to tundra or silverado a few times because of it. I love the way the tundra drives, it shifts firm an quick.. where our trucks are almost laborious to drive.
    I am scared to drop 770 on a truck I am not sure I will keep for a long time... I want a truck that I can keep for nearly a lifetime. Not sure this is it anymore.
