Can you identify (and source) this electrical component?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Edcrosbys, Aug 23, 2011.
  1. Aug 23, 2011 at 4:53 PM
    Edcrosbys
    Edcrosbys [OP] Active Member
    Northern va
    07 DC TRD
    My 4x4 green light started blinking the other day while driving in 2WD. Checked the switch and everything is in the right position. Try playing around (flipping in 4hi, 4lo, 2wd) and nothing changes.
    I start following the T/Sing procedures here http://www.ncttora.com/fsm/05+/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/034000.pdf and my switch isn't reading the correct resistances in 4-hi! Instead of spending $50 for a new switch I'd rather spend a few bucks for a resistor.
    So, the resistor (I assume) is Black with one silver stripe and has G6.V on it. Here's an image (not mine) :
  2. Aug 23, 2011 at 4:58 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    the black with silver line looks like a capacitor to me
    edit
    not sure though, caps legs usually come out from the same side...
  3. Aug 23, 2011 at 5:09 PM
    maju
    maju Well-Known Member
    Davenport Fl
    10 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
  4. Aug 23, 2011 at 5:11 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    those look like diodes, not resistors or caps.. diodes always have 1 silver line telling you which way the current flows.
  5. Aug 23, 2011 at 5:16 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    true!
  6. Aug 23, 2011 at 5:17 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    That looks like a diode to me. The silver stripe shows that is the "cathode". Put your multimeter in the diode checking mode and see what voltage drop you get across it (black of the meter to the stripe). It would be best to test out of circuit (removed).
  7. Aug 23, 2011 at 5:17 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps
    Yeap, that's a diode.
  8. Aug 23, 2011 at 5:35 PM
    Edcrosbys
    Northern va
    07 DC TRD
    Thank you!
    My el-cheapo meter doesn't have a diode test setting. When measuring resistance I expected to see ALOT of resistance one way and not much going the other. I get a quick reading of low resistance, then no connectivity. I get this each time I touch the probe to the diode. Is this expected behavior, or indicative of a bad component?
    I've verified I'm getting good contact. I get no connectivity going the other direction.
    Thank you!
  9. Aug 23, 2011 at 5:44 PM
    Edcrosbys
    Northern va
    07 DC TRD
    On 2-hi and 4-lo it's reading correct.
    On 4-hi I have:
    a short burst of low resistance (then no connectivity) going from pin 5-4 and pin 2-4
    No connectivity going from pin 4-5 or pin 4-2.
    The existing solder joints are good.
  10. Aug 23, 2011 at 7:44 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    looks like you got it handled!
