Can you identify the size of this bolt, with thread pitch?
Discussion in 'Technical Chat' started by KaptainH, Jan 11, 2019.
  1. Jan 11, 2019 at 3:14 PM
    KaptainH
    KaptainH [OP] Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    No dealer or parts vendor can tell me the size of this bolt and the shipping on it is 5 days. No dealer has it in stock. I need it to prevent front diff fluid from spewing all over the place.
    Can you tell me the size of this bolt and thread pitch? Part# is 90119-A0141.
    Long arrow
  2. Jan 12, 2019 at 1:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    2000 Work truck
    Super Springs
    Since your pictures failed to load .
    Maybe tell us just what bolt you need.
    Toyota Hardware for the Most is not expensive .
  3. Jan 12, 2019 at 1:36 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Is there an auto dismantled anywhere nearby? That looks like a standard diff plug that you could find on different Toyotas.
    :notsure:
  4. Jan 12, 2019 at 6:42 AM
    KaptainH
    Kris
    Gainesville, GA
    Not a plug
  5. Jan 12, 2019 at 6:42 AM
    KaptainH
    Kris
    Gainesville, GA
    Fixed- it’s the bolt for the diff breather bracket...
  6. Jan 12, 2019 at 7:13 AM
    deadpocketss
    deadpocketss Dingus
    Ian
    Colorado Springs, Colorado
    2010 Red PreRunner (Mia)
    Mostly patches.
    Should be a 12mm head. Don't know how long or what the pitch is.
  7. Jan 12, 2019 at 7:35 AM
    KaptainH
    Kris
    Gainesville, GA
    Yeah I saw the head size from ECGS- so I'm gonna guess it's an 8mm bolt. Just don't know length now. It's almost impossible to get to without removing other stuff.. so trial and error isn't really that easy.
  8. Jan 12, 2019 at 10:16 AM
    Wyoming09
    New Tripoli Pa
    2000 Work truck
    Super Springs
    M8 x1.25 I would guess 20 to 25mm
    Something is wrong if fluid is pushing out of that that hole .
    Or is it pushing out the breather because it is falling off
  9. Jan 12, 2019 at 10:54 AM
    KaptainH
    Kris
    Gainesville, GA
    Yeah- because the bracket isn’t secure the breather tube got pulled off
  10. Jan 14, 2019 at 6:52 AM
    96carboard
    96carboard Well-Known Member
    Go to HD and buy a bunch of metric bolts of different sizes. Cost you a couple $.
    Gunshot-6A likes this.
  11. Jan 14, 2019 at 8:01 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    If you are ever in this bind- Measure the diameter of the bolt as best you can either directly with a scale or clamp on it with an adjustable wrench and measure the gap in MM between the jaws. Then measure how many thread peaks there are in 1 mm distance along the length of the bolt. That gives your diameter and thread pitch. Use a magnifier if you need to see finer threads. An M12 x P=1.0 will have thread peaks that line up exactly on each mm mark for example. You can estimate other pitches from there.This works for standard bolts in the same way except that you count the number of thread peaks in an inch 13,16, 18,20, 24,32 ect. You can tell a "fine" or "coarse" thread pitch that way if you can't by sight or comparison.
    If you have a caliper and a thread pitch gauge all the better. I think even the cheaper HF tap and die kits still come with both thread pitch gauges.
  12. Jan 14, 2019 at 8:05 AM
    96carboard
    For anybody reading that, he means clamp onto the actual threads with the adjustable wrench, not the head where you normally put the wrench!
    @Troyken : I suspect that he doesn't actually *have* the bolt that was in there.
  13. Jan 14, 2019 at 8:16 AM
    Troyken
    NY
    Yes that is correct, the bolt body not the head, this was meant as a general post on this topic. Many people refer to a bolts size by its head size. That makes it easier if you are only looking for the correct wrench though.
