Can you install Lamin-x without taking fogs out?
Discussion in 'Lighting' started by jtkz, Feb 12, 2011.
  1. Feb 12, 2011 at 2:01 PM
    jtkz
    jtkz [OP] Active Member
    Hawaii
    PreRunner SR5
    Is this possible? Because when I try to take my fogs out, it feels as if the bottom is screwed on or something. I know that there are two things that hold it on the right and left, but when I get them free, the bottom holds down. So, that's why I'm asking if I can just directly clean the fogs and apply them while they're in? Mahalo
  2. Feb 12, 2011 at 3:49 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i did it witha hair dryer
  3. Feb 12, 2011 at 3:52 PM
    sicripp83
    sicripp83 Well-Known Member
    wboro
    sic
    is the lamin-x better than painting then yellow and where would one buy lamin-x
  4. Feb 12, 2011 at 3:54 PM
    rcfreak201
    rcfreak201 Well-Known Member
    i just took my fogs out to smoke them and if you look at the bottom screw theres a little dial behind it(same one in your headlights to adjust them up/down, left/right) its just smaller, thers a rubber thing and inside it theres a screw which connects to that little dial, not sure if im making sense but just take that screw out and the dial will spin and once thats completely loose, the two side tabs will slide out too and just push it out, same way with the install
  5. Feb 12, 2011 at 5:18 PM
    MUDFISH
    MUDFISH Well-Known Member
    Syracuse
    12 Double Cab SR5
    I did mine without taking them out... took about 5 minutes and I used a heat gun and my thumb...
  6. Feb 12, 2011 at 10:46 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    laminx is 2-3x the price. Its no better or worse. I painted, and glad I did.
  7. Feb 13, 2011 at 1:17 PM
    mickyd9990
    mickyd9990 Well-Known Member
    marc
    ri
    07 tacoma off road
    i used the laminex.. left them in and just applied it without any heat.. did it when it was about 32 degrees and it still sticks fine a couple months later.. but im not very happy with how they look.. i bought the paint and im gonna peel them off and paint it
  8. Feb 13, 2011 at 1:34 PM
    rendog
    rendog i miss my 04
    Hawaii
    2011 4x4 TRD Sport
  9. Mar 1, 2012 at 12:42 PM
    Aw9d
    Aw9d That one guy
    Az
    I did lamin-x while they were in, its kind of a pain in the ass to do. I'm not happy with them and will be ripping them off and getting the yellow paint instead.
