Can you lift your truck and still keep the stock ride quality?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kbran24, Sep 25, 2018.
  1. Sep 25, 2018 at 8:54 PM
    #41
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I have this on a gen 2 and it's plush as hell. The faster you go through ruts and potholes off-road the softer it is, especially aired down to 20psi or less. And on the street it rides firm and flat. No nose dive or body roll.
    The stock suspension is nothing special at all. If you add a spacer/block you will make it worse. Adding a quality set of shocks and springs will make it much better.
    If you want a Cadillac road ride spring for FOX or KING 2.5 progressives.
    They will be super soft and smooth on road.
    Thegenerik1 likes this.
  2. Sep 25, 2018 at 8:58 PM
    #42
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    There is no way you preloaded that OME spring to the highest perch and it rode like stock. I’ve had them set on the lowest and they did not ride like stock. Unless your stock truck rattled the dash every time you hit a bad patch of road or a pot hole.
  3. Sep 25, 2018 at 9:01 PM
    #43
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    OP if you want a good street ride and small lift up front get the Fox 2.0 non resi coilovers. I had them on my 09 and it road amazing. They raised the front about 2”. If that’s too much back the preload off the spring a little. Way better ride quality then 5100s.
    Kbran24[OP] likes this.
  4. Sep 25, 2018 at 9:02 PM
    #44
    SpeySquatch
    2016 TRD OR DCSB
    Or these...:D
    http://www.headstrongoffroad.com/st...ervoir_and_Optional_Compression_Adjuster.html
  5. Sep 25, 2018 at 9:06 PM
    #45
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
  6. Sep 25, 2018 at 9:24 PM
    #46
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    Lol well I didn’t say the highest setting, but... ok :)
