Can you mix New and Old CV Grease?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iTz IAN, Jun 20, 2012.
  1. Jun 20, 2012 at 1:51 AM
    iTz IAN
    iTz IAN [OP] Well-Known Member
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    My driver side outer boot leaked ~2-3 ounces over ~250miles from the metal band slipping off so Im trying to refill it, I went to Napa and was told that this grease can be added to the old grease ( I was very weary.....) got home and checked the back and it says to take out the original grease and use solvent to clean the old remaining grease. My question is can I mix this new grease with the standard grease without issues? I don't need the whole CV rebuild kit. Right now Im running a hose clamp to get by, also anyone know what size the smaller band is?
    o and there 45,000 on the old grease
    Thanks
  2. Jun 20, 2012 at 7:01 AM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    You can. But I would, while you're already there, remove the old grease (as much as you can) and fill with new.
