Can you physically disable passenger seat belt alarm?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shealoner, Mar 20, 2024.
  1. Mar 20, 2024 at 7:39 AM
    Shealoner
    Shealoner [OP] Well-Known Member
    2023 Tacoma SR Utility 4x4 2.7L
    2023 Sr Utility. Anyone know how to disable or modify the seat belt alarm on the passenger side?
    I'm looking for a physical option not an app or programing,not certain any would work on my stripped down work truck. I could always go pick up a spare seat belt buckle from a scrapyard, but I'm kind of wondering if anyone has just bypassed or unhook the sensor under the seat? Getting Really tired of my tool bag or the dog setting it off.
    If it was like a forklift or tractor seat sensor I could add a few spacers to increase the weight needed to set it off.
  2. Mar 20, 2024 at 7:40 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
  3. Mar 20, 2024 at 7:45 AM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
  4. Mar 20, 2024 at 7:49 AM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Scrap buckle is the answer, don’t overthink it or worse, incriminate yourself in the worst-case scenario.
    If you bypass some it’s a huge pain to have an actual passenger in your truck. Assuming you’re honorable enough to disclose that you have intentionally disabled critical safety features for them only, and that your airbag still works perfectly well.
    Seat buckles are like $10 on Amazon, I trust you can do the math.
    sock66 and Benny blanco like this.
  5. Mar 20, 2024 at 7:56 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Don’t know why you wouldn’t the programming method, but based on that it sounds like you need one of the dummy inserts to put in the buckle.
    musicisevil likes this.
  6. Mar 20, 2024 at 7:57 AM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Also have a set of the “extenders” from Amazon. Yaaay a sequel.
    tinker_troy likes this.
  7. Mar 20, 2024 at 7:58 AM
    CM52375
    CM52375 Well-Known Member
    Cody
    Tennessee
    2024 Smoked Mesquite Limited Tundra
    Yea this, you can buy a Carista, plug it in the OBD2 port and use the app to disable it. Super easy and you can always revert back if you change you mind. No dealing with extra parts that can get lost over time.
    02Duck, vaca, Hogan1966 and 5 others like this.
  8. Mar 20, 2024 at 9:09 AM
    Shealoner
    The only passengers I tend to haul around are those who refuse a seat belt at their own risk. Their mother was cut in half by a faulty seat belt in a wreck so I don't push the issue much.
  9. Mar 20, 2024 at 9:18 AM
    Shealoner
    And Ideally I would Like the alarm to go off When someone is sitting in the seat. But it goes off with less then 30 lbs on it if I hit a bump. Probably will go with a dummy, I just know I'll loose it repeatedly.
  10. Mar 20, 2024 at 9:46 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    the extenders are the best option in terms of ease, functionality, and LEO side eye
    koditten likes this.
  11. Mar 20, 2024 at 9:55 AM
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    Horrific but anecdotal and likely a lap belt from decades ago, times and tech have changed. Anyway, good luck in your quest and be sure to cover your ass when anyone else hops in. “At their own risk” verbally until you’re in a wreck and they realize they can sue you and get money signs in their eyes.
    Phlogiston, musicisevil and Chew like this.
  12. Mar 20, 2024 at 10:25 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Tether it to the seatbelt stalk.
  13. Mar 20, 2024 at 11:16 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
  14. Mar 20, 2024 at 11:25 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Someone on this forum posted you can just unplug the wiring to the buckle, i.e. open-circuit is sensed as seat belt inserted.
    Shealoner[QUOTED][OP] likes this.
  15. Mar 20, 2024 at 12:07 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Why not just insert the seatbelt?
    Phlogiston and Chew like this.
  16. Mar 20, 2024 at 2:41 PM
    Shealoner
    Not anecdotal. Also not going to argue with you over it. She was a friend.
  17. Mar 20, 2024 at 2:42 PM
    Shealoner
    It bothers me to see it. And the dog doesn't like it.
  18. Mar 20, 2024 at 3:07 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    makes sense…….
    On my last truck, I picked up a buckle from the scrap yard for $1.50
  19. Mar 20, 2024 at 3:17 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    You can just disable the audible chime you wish and not lose any functionality if someone chooses to wear the belt sitting there. I do this all the time with TIS or the dealer can do it quite easily. If you ask and explain the situation they may help you out, some will undoubtedly refuse since they may fear legal responsibility. Just providing options.
  20. Mar 20, 2024 at 3:43 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    On my 2021 the dealer(s) would not disable even though the Owners Manual says they can. It is under customizations in the owners manual. I have Techstream and it cannot disable, I purchased Carista (sp) and it cannot disable the seatbelt chimes either. Both Techstream and Carista say they do during programming but do not in actuality.
    It is possible to open the seatbelt receiver of each and deactivate the switch, or rather activate it at all times.
    Shealoner[OP] likes this.
