Can you push-start a 2013 Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AAlexander, Aug 29, 2020.
  1. Aug 29, 2020 at 1:11 PM
    AAlexander
    AAlexander [OP] Member
    Manual transmission, but I've heard that some engines can't be push started. Anyone know on a Gen2 Tacoma?
    Edit to add: Yeah, I'm pretty sure there's something in the manual about not push-starting it or you'll cause all sorts of bad things to happen. Question stands.
  2. Aug 29, 2020 at 1:32 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
  3. Aug 29, 2020 at 1:33 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I have a 2010 5 speed 4x4 manual...I've "push started" it a bunch of times...I park on a hill at work...release the brake, coast, pop the clutch and off I go...
    DiscoYaker and davidstacoma like this.
  4. Aug 29, 2020 at 1:33 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Don't use 1st gear and you'll be fine
  5. Aug 29, 2020 at 1:33 PM
    Bishop84
    Bishop84 Well-Known Member
    100% you can push start any modern manual car. Key on, let clutch out in 2nd or higher gear, ready with throttle.
    Only thing that will stop it is a shorted battery with dead cells.
    davidstacoma likes this.
  6. Aug 29, 2020 at 1:34 PM
    TreeFortRichard
    Brian
    Yeah, I was going to say always in 2nd
  7. Aug 29, 2020 at 1:37 PM
    davidstacoma
    David
    NC
    Every “non-modern” manual car I ever tried push starting back in the day also worked lol
  8. Aug 29, 2020 at 1:48 PM
    Bishop84
    Once I had a date push start me in a Dennys parking lot because she couldnt drive manual. She was a keeper lol
  9. Aug 29, 2020 at 1:49 PM
    davidstacoma
    David
    NC
    Lmao for sure!
  10. Aug 29, 2020 at 1:58 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    I find that its easier (easier on transmission as well) to push start in second gear if you can get it going fast enough. I have a 2015 v6 manual, I haven't had to push start (on this vehicle but many times on others) but 1st gear is so low so either way I'd probably try 2nd gear before 1st. I know while driving I can get down to 2mph or less without stalling in 2nd
